full coilovers for 210??
80datson
  • Replies 10
  • 3 months later...
so i went to the junk yard and found a 280z and i took off the front suspension. so now i have is 2 sets of whatsin the pic. what would i need to keep so i can lower it with some ground control lowering sleeves.. would i need to keep the shock its self? or can i buy some new ones?
280Z struts wont bolt on to the stock steering arms, and you can't really use the 280z steering arms with the 280Z struts on a 210 either..... plus you have the camber situation which has to be worked out using the 280z stuff.
280zx struts = build them into coilovers and bolt on and get some new brake lines...
