Back-Up Lights Always On
Zeusimo
A Few Days Ago I Noticed My Back-Up Lights Were On While My Dad Was Driving Away
And The Next Day I Turned On The Truck To Check And The Back-Up Lights Were On And It Was On Neutral...
Has Anyone Experienced This Before? They Worked Fine About A Week Ago And I Haven't Touched Anything
  • Replies 4
I'm going to assume it's a standard. This is the switch location.Pass side just behind the clutch arm. If those two wires were touching each other they would be on as well.
This is the automatic interlock location, same side as the standard. It is connected to the selector and has two switches. One that allows start in PARK and NEUTRAL only and another for the reverse lights.
The linkage or the switch could be badly adjusted or the two reverse wires (Red/Black stripe) touching each other.
Huge Thanks!!!
