matwood Posted September 29, 2010 Report Share Posted September 29, 2010 Are all ring and pinion gears the same? I have a 3.70 LSD and I want 4.44 gears. Can I just go find a 4.44 R160 and pull out the R and P and swap em with mine? Maybe weld the 3.70 non LSD for the hell of it.. haha.. Just a thought and I couldn't find anything on the forums or on the net. Quote Link to comment
matwood Posted September 29, 2010 Author Report Share Posted September 29, 2010 no one knows?! I've already found a 4.11 and a 4.44, just waiting on the information! Quote Link to comment
sssr20det510 Posted September 29, 2010 Report Share Posted September 29, 2010 Yes you can if you want the 4.44 and lsd you have to swap the ring and pinion, they never made a 4.44 with lsd Quote Link to comment
hang_510 Posted September 29, 2010 Report Share Posted September 29, 2010 Are all ring and pinion gears the same? Can I just go find a X.XX R160 and pull out the R and P and swap em with mine? no. yes. look for proper gear meshing (NO wear) and replace the bearings. if you dont keep the R&P matched, failure is imminent! Quote Link to comment
Everat Posted September 29, 2010 Report Share Posted September 29, 2010 theres a diff for sale locally that is supposed to be a 4.44 lsd. I was thinking about it but 4.44 is a little crazy isnt it? I have a sr20de anyone know what kind of rpms id be at on the freeway with 4.44s? Quote Link to comment
hang_510 Posted September 29, 2010 Report Share Posted September 29, 2010 http://www.angelfire.com/fl/procrastination/rear.html Quote Link to comment
matwood Posted September 29, 2010 Author Report Share Posted September 29, 2010 MMMM... 4.11's! Im going to get that rear end tonight. Should be good... Quote Link to comment
datzenmike Posted September 30, 2010 Report Share Posted September 30, 2010 The ring an pinion will need to be set up by a competent shop. You can't just bolt them in an go. No two diffs are the same and are made to a +- tolerance. It is easier and cheaper to set the gears individually. The pinion must be centered forward and back and the ring gear side to side. These are set using micrometers and dial gauges with shims and crush washers selected to get the correct 'gear lash'. The drive force could end up on the outer tips of the gear teeth or to the inside or outside of the teeth where they are not the strongest. Get it done right. Quote Link to comment
matwood Posted September 30, 2010 Author Report Share Posted September 30, 2010 cool, thanks mike. finding a competent shop around here will be the next big challenge for me. what kinda price do you think i'd be lookin at for just swapping the R and P, maybe cleaning things up too? Quote Link to comment
hang_510 Posted September 30, 2010 Report Share Posted September 30, 2010 i only set the ring when i did mine, and it took us a long hour. Quote Link to comment
datrod Posted October 1, 2010 Report Share Posted October 1, 2010 cool, thanks mike. finding a competent shop around here will be the next big challenge for me. what kinda price do you think i'd be lookin at for just swapping the R and P, maybe cleaning things up too? I did a swap in my Z a couple years ago. Had unitrax here in So Cal set it up for me. Went from a 4:63 to 4:38 all new bearings and install was about $400.00 Quote Link to comment
