L18_510 Posted September 27, 2010 Report Share Posted September 27, 2010 ok my four door 510. is cool but i kind of need help to fix or a solution for my back tires they are flaring to much in, i need cambers but i kant find it. help Quote Link to comment
datzenmike Posted September 27, 2010 Report Share Posted September 27, 2010 Someone will jump in here and explain in depth, but as I understand it the camber problem is caused anytime a 510 is lowered in the rear. A solution is to slot the bolt holes in the crossmember. Quote Link to comment
HRH Posted September 27, 2010 Report Share Posted September 27, 2010 Is this for real? The grammar and spelling makes me wonder. Yes, what Mike said, lots of companies offer slotted crossmembers. They're pretty spendy. You can also make yours slotted with the right fabrication tools and some skill. The other option is to raise the car if you don't have any money for a slotted crossmember. Save up, then lower later. Quote Link to comment
INDY510 Posted September 27, 2010 Report Share Posted September 27, 2010 or get wider tires .......... and forget about getting cambers Quote Link to comment
