SIXTY-NINE-DIME Posted September 6, 2010 Report Share Posted September 6, 2010 so i bought a z and for some reason the blinkers dont work. the fuses are good. can any one tell me where the flasher relay is? Quote Link to comment
Skib Posted September 6, 2010 Report Share Posted September 6, 2010 hangin under the dash like the 510 if its an S30 could be your switch too. what year Z is it? Quote Link to comment
datzenmike Posted September 6, 2010 Report Share Posted September 6, 2010 Turn 4 ways on and check all bulbs flashing. Now swap the 4 way with the signal flasher unit. Anything change? Would help to know year of 240/260/280z/zx. Quote Link to comment
SIXTY-NINE-DIME Posted September 6, 2010 Author Report Share Posted September 6, 2010 sorry haha i believe its an s130. its an 81 280zx and the 4 ways dont come on either Quote Link to comment
datzenmike Posted September 6, 2010 Report Share Posted September 6, 2010 See if the flasher units are even there. Quote Link to comment
SIXTY-NINE-DIME Posted September 6, 2010 Author Report Share Posted September 6, 2010 where would that be? i know nothing about z's:/ Quote Link to comment
datzenmike Posted September 7, 2010 Report Share Posted September 7, 2010 I know less about them. On the 4cyl cars/trucks they are usually under dash near the steering column. Quote Link to comment
I'm BLUE Posted September 7, 2010 Report Share Posted September 7, 2010 Go to the parts store ,,, ask them for one ,,, then look for it if you are not entirely sure ! It should only be like $10 or so ( give or take ! ) ---> My windshield leaked down on mine ,,, filled it full of water ,,, ruined ,,, tis a quick fix ( on a 73 240z at least ) My 1973 240z it is located on Drivers Side ---> Near Column Center towards the bottom/underside area IIRC ? :huh: I am sorry I don't know the location on the 280zx s130 series ??? Best of Luck Quote Link to comment
SIXTY-NINE-DIME Posted September 7, 2010 Author Report Share Posted September 7, 2010 still no luck:/ im sure ill figure it out eventually Quote Link to comment
datzenmike Posted September 8, 2010 Report Share Posted September 8, 2010 Well if they are missing you won't find them, right? Have someone who knows look for them. Quote Link to comment
SIXTY-NINE-DIME Posted September 10, 2010 Author Report Share Posted September 10, 2010 still no luck. i found a few relays under the passenger side but none that fixed it. the only relay i see missing is one under the hood and i went to autozone and the flasher they handed me wasnt the same as the one that was missing Quote Link to comment
datzenmike Posted September 10, 2010 Report Share Posted September 10, 2010 Here's what you are looking for: They may be longer or they may be clear and you can see the insides. Usually they are an aluminum can like the bottom one. All have two wires arranged in an L shape. They will be in the car likely and are NOT relays. Again if they are missing you won't see them. Look for an empty L shaped plug. . Quote Link to comment
SIXTY-NINE-DIME Posted September 10, 2010 Author Report Share Posted September 10, 2010 Here's what you are looking for: They may be longer or they may be clear and you can see the insides. Usually they are an aluminum can like the bottom one. All have two wires arranged in an L shape. They will be in the car likely and are NOT relays. Again if they are missing you won't see them. Look for an empty L shaped plug. . thank you sir. as soon as i get a chance ill look and let u know how it goes. thanks again Quote Link to comment
