MicroMachinery Posted August 31, 2010 Report Share Posted August 31, 2010 Over the past few years I've accumulated many Datsun goods. I'm moving this week, so I need to begin thinning out my stock to simplify my collection. Prices do NOT include shipping. For starters, I have a bunch of 75' 620 goods that need a new home. Pics. $15 -Wiper MotorSOLD -Rear Marker lights(Pair; no cracks) -Horns(Pair) -Door Handles(Pair) $10 -Air Ducts(Pair)-SOLD -Door Pulls w/ Passenger side Handle+Window crank w/ Trim-SOLD $5 -Dome Light Assembly(No Lens) -Hood Arms(Pair)SOLD -Tail light bucket -Headlight switch -All other switches/relays(All) -Under hood light+switch(Together)-SOLD -Clock DeleteSOLD -Voltage Regulator -Gas tank filler neck -Air Vents(Pair; missing 2 fins I believe on the right side) -Tailgate(Very straight, needs repainting)SOLD $8 -Factory Rubber Floor mat(Single tear on passenger side, hole for shifter. Could use a bath)SOLD $20 -Pedal Assembly(Clutch, Brake, Accelerator Pedals) $15 -Windows(Each. Driver, Passenger, and Rear windows. Have solid and slider rears) $5 -Lower Valance(Not sure what shape it's in, but it's not perfect, I know that) $20 -Steering wheel -Drive line(2-piece) -Grille I have other a few other 620 odds and ends lying around as well. Too many to list them all right now. Link to comment
MicroMachinery Posted August 31, 2010 Author Report Share Posted August 31, 2010 SOLD! -210 Casting Open Chamber Head. Totally cleaned and gone through. 100% Complete. Not run since rebuild, Ready to bolt on. $150 -Single Sidedraft Weber + Cannon Manifold w/ spacers. No air cleaner, no linkage. I have never used this carb, so I'm not sure if it needs anything. $100 -Weber 32/36 DGV w/ L16 intake manifold and spacer plate. Manual Choke. $75 -Weber 32/36 DGAV SOLD -Weber 32/36 DFV w air cleaner base-plate. $50 -Recently rebuilt Hitachi Carb designed for an L16. Came off a 70-71 521. $15 -K&N Filter assembly for 32/36 DGV. New element. Oval style pictured. -Aluminum Adaptor Base Plates(Each) There WILL be Moar.. Link to comment
metalmonkey47 Posted August 31, 2010 Report Share Posted August 31, 2010 whats the height of the weber air cleaner? Link to comment
MicroMachinery Posted August 31, 2010 Author Report Share Posted August 31, 2010 whats the height of the weber air cleaner? 3 1/2" from base to top. Link to comment
H5WAGON Posted August 31, 2010 Report Share Posted August 31, 2010 So how far from Portland..? I might want that head. And the side draft weber setup. Link to comment
Radim Posted August 31, 2010 Report Share Posted August 31, 2010 Do you have a working headlight switch and wiper switch for a 620? (73) Link to comment
MicroMachinery Posted August 31, 2010 Author Report Share Posted August 31, 2010 So how far from Portland..? I might want that head. And the side draft weber setup. I'm a little over an hour from Portland. Link to comment
MicroMachinery Posted August 31, 2010 Author Report Share Posted August 31, 2010 Do you have a working headlight switch and wiper switch for a 620? (73) I have the headlight switch. I'm not sure, but I believe one of the other 2 switches are the wiper switch. Link to comment
RadioRedline Posted August 31, 2010 Report Share Posted August 31, 2010 says u cant recieve new mssgs. 5$ shipped for the clock delete and i'll take it! Radio Link to comment
MicroMachinery Posted August 31, 2010 Author Report Share Posted August 31, 2010 says u cant recieve new mssgs. 5$ shipped for the clock delete and i'll take it! Radio So... you want me to take my time to go to the post office, pay MORE than $5 to mail it to you up in Canada, and then get back to packing all my stuff to move? Am I reading you correctly? Shall I insure it for you as well? <_< 4 Link to comment
MicroMachinery Posted August 31, 2010 Author Report Share Posted August 31, 2010 I have a couple headers, too. One is a shorty with a universal type flange, and the other one is a long tube header that goes through a glasspack and exits to the driver's side before the rear tire. $75 for the long tube/side exit exhaust, $50 for the shorty. Engines. I have a few L16 cores. 2 of which are known runners, the other two.. well, I'd imagine will need to be torn down and rebuilt. These two I got with a car over a year ago. Don't know what the internals look like. I'll take $40 for each of em. This one was the engine that came in my 521 when my Dad passed it down to me. I rebuilt the number's matching engine that he had with it, and took this one out. It had some blowby, but it was running. $80. This engine came in that orange 510 wagon that I had. It ran, but I think the headgasket may need to be replaced, and the timing cover is missing. $60. I also have a disassembled L16 short block. Comes with crank and pistons. It has been honed and hot tanked. It needs bearings/rings and gaskets. If you're looking to build an L16 from the ground up, this will make it easy. One of the pistons has a little surface rust on it, but I rubbed most of it off with my finger. $100. Heads. I have a few heads that I can get rid of, too. A w58, a w53, and an a87. The w58 is the open chambered L20b head with the round exhaust ports. The liners have not been removed. This came off a running engine that I tore down to rebuild, and never got around to it. $50. The w53 head is the closed(peanut) chamber design. It looks like the number 1 cylinder had something bounce around inside of it, so the quench areas of the head are a little chewed up. It wouldn't take a whole lot if you knew an aluminum welder to fill in the divots and then have it machined back down flat(that was my plan). $60. The a87 head is my nicest closed chamber head. Nothing special; I'd rebuild it before using it.SOLD I also have a Z22 head, along with valve cover, distributor, intake and exhaust manifolds, timing cover, water pump, distributor drive, timing chain/components and carburetor. $75 for everything. Still have more to list.. Link to comment
skunk Posted August 31, 2010 Report Share Posted August 31, 2010 damn, im seeing things i want. i might have to come do some shoping at your place. if you need some help with your move i might be in the area next weekend, ill give you a call if i make it up. Link to comment
RadioRedline Posted August 31, 2010 Report Share Posted August 31, 2010 So... you want me to take my time to go to the post office, pay MORE than $5 to mail it to you up in Canada, and then get back to packing all my stuff to move? Am I reading you correctly? Shall I insure it for you as well? <_< It can be mailed in a bubble envelope for next to nothing. 5 + ship to canada Radio Link to comment
pharouh Posted August 31, 2010 Report Share Posted August 31, 2010 Woohoo! I love 620 parts! I'll take the underhood light/switch, the air ducts,and the arm rests. how much for this shipped to 46176? Thanks,John Link to comment
MicroMachinery Posted September 1, 2010 Author Report Share Posted September 1, 2010 PM sent. Link to comment
Chumbai Posted September 1, 2010 Report Share Posted September 1, 2010 Do you have any 4.38 or 4.88 rear end for sale? Link to comment
MicroMachinery Posted September 1, 2010 Author Report Share Posted September 1, 2010 Do you have any 4.38 or 4.88 rear end for sale? I have an aluminum housing Wagon Rearend. It needs bearings.. I don't remember what the gear ratio is on those.. Link to comment
ScubaT Posted January 4, 2012 Report Share Posted January 4, 2012 Are the windows oem, and would you ship? Link to comment
fuzz's '71 510 Posted January 4, 2012 Report Share Posted January 4, 2012 $150 -Single Sidedraft Weber + Cannon Manifold w/ spacers. No air cleaner, no linkage. I have never used this carb, so I'm not sure if it needs anything. You still got this? Link to comment
izzo Posted January 4, 2012 Report Share Posted January 4, 2012 lol. thread from the dead!! Link to comment
