69FJWagon Posted August 23, 2010 Report Share Posted August 23, 2010 HELP guys! I know someone here can help me out I really try usally to figure stuff out but I am stumped I drove the kc friday after work and when I left the house I had no issues and within 3 miles of my house I notice my charge light is on and I have no gauges my fuel says E and I know its full it read so when I left my house as well as my temp gauge is reading cold, I stopped off at Lisas friends shop and grab the tester 14.3 volts so the alt. is working and the battery is good I found a blown fuse but it didnt change anything I was thinking a loose or bad ground but cant seem to find anything... Any ideas where to look or what to look for??? Thanks in advance Clayton Quote Link to comment
mklotz70 Posted August 23, 2010 Report Share Posted August 23, 2010 dude.....you know you can call me with electrical probs :) possibly the volt reg on the back of the instrument cluster. Not sure if that will cause the charge light. I'd have to look up the schematic. Maybe someone's got a better idea off the top of their head. Looking at the '76 schemat....the charge light only goes to the external volt regulator. The light comes on when there's no juice from the alt....you may just have a bad connection in the plug at the regulator or behind the instrument cluster. The other power to the gauges is from pin 8 on the back of the cluster...it comes from the blue/black wire on the 10a fuse on the ignition side of the fuse block. That fuse also feeds the hazard lights and a couple of other things I've already forgotten in the 30 seconds it took me to get back on the forum and type this :( LOL. Anyway....the little volt reg on the back of the cluster may have a prob. One of the other items on that line may have caused the fuse to blow. You may want to do some poking around behind the gauges with a test light :) Quote Link to comment
fastdadd Posted August 23, 2010 Report Share Posted August 23, 2010 mine did the same thing i would replace the fuse and it would last a few weeks and pop again...turns out the turn signal flasher would bump something and ground out Quote Link to comment
yello620 Posted August 23, 2010 Report Share Posted August 23, 2010 Looks like the bottom left fuse should be the one that powers all of those items, also powers your reverse lights. Quote Link to comment
69FJWagon Posted August 23, 2010 Author Report Share Posted August 23, 2010 Thanks guys I will check things out after work today and let you know what I find out Clayton Quote Link to comment
69FJWagon Posted August 25, 2010 Author Report Share Posted August 25, 2010 FIXED thanks to my buddy Mike him and I tackled it this afternoon turned out to be a few issues a bad connection and a badly corroded connector and the fuse was corroded also so one by one the issue got fixed Thanks guys for pointing me in the direction :cool: :) Clayton Quote Link to comment
justin 620 Posted September 27, 2010 Report Share Posted September 27, 2010 FIXED thanks to my buddy Mike him and I tackled it this afternoon turned out to be a few issues a bad connection and a badly corroded connector and the fuse was corroded also so one by one the issue got fixed Thanks guys for pointing me in the direction :cool: :) Clayton Hey, sorry if this is a stupid question, but what exactly did you do? Because I've been having this same exact problem lately and it's only been getting worse, any help would be vastly appreciated... Quote Link to comment
