RacnJsn95 Posted December 29, 2007 Report Share Posted December 29, 2007 I figured rather than try and repair all the little dents and dings in my 620 bed, it might not be a bad idea to just replace the bed... I found a PREEMO short bed in the local junkyard (no hood or fenders though :(). They said I could have it for $75 bucks. So, next weekend I'm going to go down there and get it... They said they'd lift it up with the fork lift or something, while I unbolt it. So in preparation, what tools should I take? And what is the easiest way to go about removing the bed. Quote Link to comment
Figbuck Posted December 29, 2007 Report Share Posted December 29, 2007 Maybe you will need a cordless sawzall and extra batteries. Maybe not. How lucky do you feel? I just took my bed off this summer, I think you saw my botofuckit pictures. Seven of the bolts came right off. I mean they were stuck on, I needed to get a 3/4" extension and a breaker bar to get them started off. Some were still hard to turn, so I hosed some Liquid Wrench up on the threads above the nut. That worked great. Of course, the last one was a total hassle. The little tab that keeps the bolts from spinning got bent and was kind of spinning and kind of catching sometimes for about two spins then slip again. I let the oil penetrate for a while and finally got a big vicegrip on the tab that would grab it. It took me about an hour all together. I suppose I could have used an impact wrench but I was too lazy to drive down to my shop to get it. A long time ago, I pulled the bed off of my 521 and had to cut all the bolts off and went through about $45 worth of the good Lennox sawzall blades. I remember that the impact that I used creamed the nuts and it was a nightmare. Not fun. Quote Link to comment
slodat Posted December 29, 2007 Report Share Posted December 29, 2007 PB Blaster is your best friend for stuff like this. SOAK the bolts in it.. a couple times. Quote Link to comment
BEEBANI Posted December 29, 2007 Report Share Posted December 29, 2007 Does this mean you might have some good extra parts from one of the 2 beds that you would part with? I'm looking for the right rear corner panel, and a good set of tail light housings. Quote Link to comment
irsa76 Posted December 29, 2007 Report Share Posted December 29, 2007 Advantage of my flatbed, I can see the bolts from the side and drown them in WD40. Plus the bed is only a couple of years old so the bolts aren't rusted. Quote Link to comment
