lalo.pineda Posted July 17, 2010 Report Share Posted July 17, 2010 hey i recently had a 240sx with an sr20det in it. my question is will the harness still work for the swap into a datsun 510?or will i have to buy a new harness??the harness was converted to work with the 240 sx ohh and also will i need these fuse/relay boxes?? any help would be awsome Quote Link to comment
sssr20det510 Posted July 17, 2010 Report Share Posted July 17, 2010 Yes the harness will work no you don't need the fuse box Quote Link to comment
lalo.pineda Posted July 17, 2010 Author Report Share Posted July 17, 2010 Yes the harness will work no you don't need the fuse box will it be the same process as in ICEHOUSE's Wiring Diagram Or will i have to do something different???thanks for the help Quote Link to comment
BoostinBen Posted July 17, 2010 Report Share Posted July 17, 2010 One thing you will find is that the harness from a 240 is wayyy to long for the 510 .. you extended it for the usdm 240 and now you can either try and tuck all the extra or shorten it. Quote Link to comment
lalo.pineda Posted July 17, 2010 Author Report Share Posted July 17, 2010 if i shorten it will i just have to clip the wires and tape them back or would i have to solder them?? Quote Link to comment
lalo.pineda Posted July 17, 2010 Author Report Share Posted July 17, 2010 ohh and one more thing would that top oil relocation kit still fit or would i have to transfer it back to the bottom??? 1 Quote Link to comment
dennis Posted July 26, 2010 Report Share Posted July 26, 2010 if i shorten it will i just have to clip the wires and tape them back or would i have to solder them?? I seriously do not think you should be touching wires if you are asking this question. Quote Link to comment
Icehouse Posted July 26, 2010 Report Share Posted July 26, 2010 solder!!!! and heat shrink them. Quote Link to comment
Denken Posted July 26, 2010 Report Share Posted July 26, 2010 Your good if its too long just follow the steps below. Step 1. Wrap extra (see diagram) Step 2. Repeat :P Seriously tho, good luck wire swap sure it will be Awesome! -Denk Quote Link to comment
LeX Posted July 28, 2010 Report Share Posted July 28, 2010 get rid of the fram filter! Quote Link to comment
