FoxyRoadster Posted July 12, 2010 Report Share Posted July 12, 2010 I know its probably overkill but if you're breaking rear ends on a goon might consider getting a ford or gm rear end cut down to fit. Can find them everywhere, wont cost but a few hundred to get cut down and axles (with spares) made. I'm considering the ford one cause they had the same datsun lug patern. Quote Link to comment
hang_510 Posted July 12, 2010 Report Share Posted July 12, 2010 ...because Wagdatto broke his 510 goon's axle with a stock KA24DE. But VGwagon has a RX7 rear end swap that looks interesting wasnt the bozo rear welded??? not only interesting, but functional! good write up as well. it seems the the ford rear creates the fewest obstacles to end up w/an LSD in a g00n. 99% sure thats what ill end up with for the VQ im dreaming of :mellow: Quote Link to comment
