jhughes26 Posted August 3, 2010 Report Share Posted August 3, 2010 alright, here's something thats really weird. recently bought an 80amp alternator for the hell of it. installed it less than a month ago, everything's great. one day it doesn't start, so I charge the battery and go buy a volt meter. After charging for a day and a half the battery reads 12.2 volts, turn on the headlights and it drops down to 11.8ish, everything's good so far. then I crank the car and its reading all over the place, from 9 to 12, no consistency. so I put a brick on the throttle to keep the revs high and it settles in at around 10.51 so looks like my alternator is crap, but I just got it, is there anything else that could cause this? Quote Link to comment
banzai510(hainz) Posted August 3, 2010 Report Share Posted August 3, 2010 80amp alternator????? I assume this is a Internal regulatedted type. as Nissan made the bigger amp alts later and they were IR type. Now if your car has a EXTERNAL VOLT REG and you put a INTERNAL alternator on there it might just do this waht your saying. So we dont know what you have as a set up just that you have said you replaced a Alternator. yes some alternators suck!!!!!!! Quote Link to comment
