teddatsun Posted July 1, 2010 Report Share Posted July 1, 2010 lights wipers ect. work. not starting. mayb theres a wire that needs to be connected to indicate that it is in park before it will start? Quote Link to comment
mike Posted July 1, 2010 Report Share Posted July 1, 2010 neutral safety switch, If theres two wires just hanging around under there that you disconnected splice them together... should work. Quote Link to comment
izzo Posted July 1, 2010 Report Share Posted July 1, 2010 weird, mine was switched from auto to clutch also. Not sure what they did, but i didnt notice anything spliced. Quote Link to comment
damon Posted July 1, 2010 Report Share Posted July 1, 2010 Yeah it's gotta be the neutral safety. Mine was converted and I can see the jumper on the harness down by the transmission. Quote Link to comment
teddatsun Posted July 2, 2010 Author Report Share Posted July 2, 2010 thanks for everyones input. any idea what color the neutral safety wire is? its also a L20B that is in it now if that matters. Quote Link to comment
datzenmike Posted July 2, 2010 Report Share Posted July 2, 2010 Black/White on the 620 and Black/Yellow on the 510. IIRC. Quote Link to comment
philcas1987 Posted July 2, 2010 Report Share Posted July 2, 2010 There should be a relay on pass side in front of strut tower with two black/yellow wires. With a test light find the one that gets power when you crank it over. That will be your starter wire. Better yet use that wire to trigger a bosch relay for more starting power. Quote Link to comment
