sdsurf Posted December 15, 2007 Report Share Posted December 15, 2007 Does anyone have any pics of a stock 521 L-16 engine bay? Quote Link to comment
Pacific coast Datsun Posted December 16, 2007 Report Share Posted December 16, 2007 I do..on my 71 521... Quote Link to comment
71-521 Posted December 16, 2007 Report Share Posted December 16, 2007 was there something in particular you were looking for? Quote Link to comment
sdsurf Posted December 16, 2007 Author Report Share Posted December 16, 2007 Specifically the passenger and driver fender wall. Location of resistors, relays, etc... Quote Link to comment
521Lvr Posted December 16, 2007 Report Share Posted December 16, 2007 hey P.C.D. is that pic b4 or after you used the nevr dull.:lol: Quote Link to comment
Pacific coast Datsun Posted December 17, 2007 Report Share Posted December 17, 2007 SD surf, come down & see it in person if need be. 521lvr....thats an absolute BEFORE pic :D Quote Link to comment
banzai510(hainz) Posted December 17, 2007 Report Share Posted December 17, 2007 72 521 Quote Link to comment
DanielC Posted December 17, 2007 Report Share Posted December 17, 2007 I took some pictures of my 521 engine bay today, But my camera is old school, has film in it. I took the film in for processing this morning, expect it back on Thursday. I took pictures of the sides of the engine compartment, with the battery and the air cleaner snout out of the way Quote Link to comment
sdsurf Posted December 17, 2007 Author Report Share Posted December 17, 2007 PCD, Oh trust me I plan on it... I will post pics of the truck I picked up when I bring it home Mike Quote Link to comment
DanielC Posted December 18, 2007 Report Share Posted December 18, 2007 Roostmonkey. What brake master cylinder in in the red truck? Quote Link to comment
DanielC Posted December 20, 2007 Report Share Posted December 20, 2007 Ok, I am going to try to post some pictures of the sides of the engine compartment on my 521. Some of it is not stock. This is the left side. The corner of the box you see on the left side of the picture is a capacitive discharge ignition kit, bought at Radio shack, in the late 1970's Notice the just cleaned and now working washer bag. Below the coil in the ballast resistor, the relay above the coil is the E-1 relay, that switches the retarded set of points into the circuit, a pollution control device. This is the right side, looking slightly forward. The horn relay in in front, the headlight relay is in the middle. I did not take the time to figure out that the third relay in this picture did. The non stock little blue relay controls the high beam lights for the outer two headlights only. This is the right side of the engine compartment, looking to the rear. This truck has an ammeter installed, and the fuse box was also redone. I have not decided if I want to leave the ammeter in the truck, or replace it with a voltmeter. I am sorry, this is not quite the stock condition truck pictures you were looking for, but I hope they can be of some help to you. Quote Link to comment
sdsurf Posted January 29, 2008 Author Report Share Posted January 29, 2008 bringing this current Quote Link to comment
DanielC Posted January 29, 2008 Report Share Posted January 29, 2008 What are you looking for? These trucks are 38 years old. It is going to be hard to find one totally stock. Quote Link to comment
banzai510(hainz) Posted January 29, 2008 Report Share Posted January 29, 2008 521 lvr truck looks pretty stock to me Quote Link to comment
Pacific coast Datsun Posted January 29, 2008 Report Share Posted January 29, 2008 Heres the dr side...lemme know if you want a close up of the pass. side relays,,, Quote Link to comment
DanielC Posted January 29, 2008 Report Share Posted January 29, 2008 The first two pictures show vacuum motors on the air filter housing horn. later 1971, or 1972 trucks? I Have three 521's, two 1970, and one 1971. The 1971 truck had an evaporative emission control system on it. None of my three trucks had the vacuum motor on the air cleaner. PCD's picture also has the vacuum motor. PCD, nice looking engine bay. What is the serial number of your truck, PCD? SDSurf, what is the serial number of your truck? I have the serial numbers for my trucks, but the power is off here, and I an doing this on my laptop. Update. PL 521 207797, 1970. This truck had round reflectors, no marker lights. The engine bay harness has connections for fog lights, but the truck does not have a fog light switch option. I got this truck used, it did not have the original engine. The front fenders have a rounder contour on the lower front than my other two 521's PL 521 371684, 1970. This truck has side marker lights. Just a normal truck, but it now has a five speed., and a L-18 engine in it. PL 521 394191. 1971 This truck has an evaporitive emission system on it. Quote Link to comment
sdsurf Posted February 2, 2008 Author Report Share Posted February 2, 2008 Ok hear goes... Hope I can explain this. On the cluster that goes to the coil and dist there are 5 wires. One wire goes to neg coil. On wire goes to right of resistor. 2 wires go to coil. WHere does the 5th go? On the cluster that goes to the left side of the resistor there are 3 wires. 1 goes to the resistor. Where do the other two go? Mike Quote Link to comment
sdsurf Posted February 2, 2008 Author Report Share Posted February 2, 2008 serial is 356122 Quote Link to comment
DanielC Posted February 2, 2008 Report Share Posted February 2, 2008 What are the wire colors by the coil, you need help with? Briefly, when the ignition key is in the run position, power goes through the ballast resistor, and then to the + side of the coil. The - side of the coil goes to the advanced set of points. There is a second wire on the - side of the coil that goes to a relay, that connects the retarded set of points to the coil under some limited operating conditions. The advanced set of points stays in the circuit even when the relay is on. There are two seperate wires that comes from the ignition switch, that has power only in the start position. One of these wires goes to the starter solenoid. The other wire goes to the + side of the coil, so the coil gets full battery voltage when you are trying to start the engine. Get me the wire colors, and I will spend a little time with a magnaifying glass, the schematic I have, and maybe even looking at my truck, to confirm wire colors. Hopefully the two trucks were made when they were using the same color coded wires. Quote Link to comment
DanielC Posted February 3, 2008 Report Share Posted February 3, 2008 Here is the colors I found on the coil, and ballast resistor of my truck, anfd it even agrees with my wiring diagram. The end of the ballast resistor closest to the cab has one wire, black with a white stripe. This wire goes back to the fuse box, and is hot with the key in the run, and start position. The front end of the ballast resistor has one wire, black with a red stripe. This wire loops up to the + terminal on the coil. The + terminal on the coil has another black wire with a red stripe on it, this wire goes back to the ignition switch. This wire is hot only when the key is in the start position. The - terminal on the coil has two wires on it. One wire is black with yellow, the other wire is blue with white. The black with yellow wire goes to the advanced set of points on the distributer. The blue with white goes to the E-1 relay, and the relay sometimes causes the distributer to run on the retarded set of points. Quote Link to comment
sdsurf Posted February 4, 2008 Author Report Share Posted February 4, 2008 Here is the colors I found on the coil, and ballast resistor of my truck, anfd it even agrees with my wiring diagram.The end of the ballast resistor closest to the cab has one wire, black with a white stripe. This wire goes back to the fuse box, and is hot with the key in the run, and start position. The front end of the ballast resistor has one wire, black with a red stripe. This wire loops up to the + terminal on the coil. The + terminal on the coil has another black wire with a red stripe on it, this wire goes back to the ignition switch. This wire is hot only when the key is in the start position. The - terminal on the coil has two wires on it. One wire is black with yellow, the other wire is blue with white. The black with yellow wire goes to the advanced set of points on the distributer. The blue with white goes to the E-1 relay, and the relay sometimes causes the distributer to run on the retarded set of points. The group of wires on the cab side of the resistor has i wire to the resistor (black with white stripe) and one black wire and one blue wire with a red stripe. The group going to the coil - black with red stripe to front resistor, black with yellow to - coil, then a long tail with black with yellow stripe, blue with white stripe and an insullated yellow (white?). http://i273.photobucket.com/albums/jj237/sdsurf3573/IMG_00391.jpg cab side resistor grouping http://i273.photobucket.com/albums/jj237/sdsurf3573/IMG_00401.jpg coil side overview http://i273.photobucket.com/albums/jj237/sdsurf3573/IMG_00411.jpg coil long tail close up Quote Link to comment
DanielC Posted February 4, 2008 Report Share Posted February 4, 2008 First picture, 391, Blue with red marker, black wire, bullet terminal ends. These two wires go to a solenoid on the side of a stock carb. The solenoid is only used in third gear, throttle closed, clutch pedal not depressed. This is a pollution control feature. Second picture, 401, Black with yellow marker, .250 female spade connector. This wire goes to the advanced set of points in the distributer. Blue with Yellow wire, .312 female spade connector. This wire goes to the retarded set of points. Yellow wire, with a white marker, female bullet connector. this wire goes to the temp sender, on the bottom half of the thermostat housing. Third picture, 411, looks like the same wires as picture 401, with an extension cord on the ground. Quote Link to comment
sdsurf Posted February 5, 2008 Author Report Share Posted February 5, 2008 First picture, 391, Blue with red marker, black wire, bullet terminal ends.These two wires go to a solenoid on the side of a stock carb. The solenoid is only used in third gear, throttle closed, clutch pedal not depressed. This is a pollution control feature. Second picture, 401, Black with yellow marker, .250 female spade connector. This wire goes to the advanced set of points in the distributer. Blue with Yellow wire, .312 female spade connector. This wire goes to the retarded set of points. Yellow wire, with a white marker, female bullet connector. this wire goes to the temp sender, on the bottom half of the thermostat housing. Third picture, 411, looks like the same wires as picture 401, with an extension cord on the ground. Awesome!!! Thanks Quote Link to comment
