85NAPSZ Posted June 23, 2010 Report Share Posted June 23, 2010 So, I'm just going to be honest and straight up - I've never really worked on a car before, until yesterday. Sure, I've watched my dad work on them since I was old enough to hold a flashlight, but I've never done work by myself without supervision. Well, I've now replaced a half shaft, alternator, head gasket, thermostat housing, plugs with new wires, distributor cap with ignition rotor, front bumper, and installed a new interior, all in one day. Well, we were using my truck to haul all these shiny new pieces and when we were pulling up to his house again there was this terrible sound and bumping coming from up under my truck. We jacked it up and found a bunch of plastic/rubber down the street. We finally discovered that was my driveshaft bushing. So, now I have even more work to do..yay. Any tips on replacing the bushing? I've already got a good idea as to what I have to do, I just want to make sure there aren't any hidden secrets to this. Quote Link to comment
datzenmike Posted June 23, 2010 Report Share Posted June 23, 2010 The actual carrier bearing rarely fails, though I have heard of lots of people replacing them. Usually what goes bad is the rubber insulator that supports the outer side of the bearing to the frame. If this is the case, trim away all the old rubber and the outer metal ring. I used a piece of 1/4" conveyor belt trimmed to about an inch and a half to two inches wide and long enough to coil around the bearing until it would just fit snugly inside the U shaped strap that bolts it down. The strip cannot be foam rubber, it has to be much more solid like tire rubber. You could wrap it with stove pipe wire or a large gear clamp to help hold it until tightened down. It must be very snug when finished or it will shake apart. I did this as a temporary fix but it worked so well I left it. Cost $0.000, no vibration and clunking........ priceless. Quote Link to comment
85NAPSZ Posted June 23, 2010 Author Report Share Posted June 23, 2010 Yeah, it's the rubber. So you suggest using a conveyor belt? lol Quote Link to comment
datzenmike Posted June 23, 2010 Report Share Posted June 23, 2010 I used a strip of conveyor belt but equivelent will work. The stock insulator is almost impossible to find, certainly not at the dealer. For the work involved this is easier and as good. Quote Link to comment
85NAPSZ Posted June 23, 2010 Author Report Share Posted June 23, 2010 Alright, thanks! Good thing we've got his 240 working again. Quote Link to comment
datzenmike Posted June 23, 2010 Report Share Posted June 23, 2010 Think jelly roll and wrap around, secure with large gear clamp or wire install securely, good to go. Quote Link to comment
]2eDeYe Posted June 23, 2010 Report Share Posted June 23, 2010 mmmm Jelly roll :P Thanks for posting pics of my awesome new isolator :D Quote Link to comment
datzenmike Posted June 23, 2010 Report Share Posted June 23, 2010 Ha ha I got the best of that deal. (sucker) Naw, it was perfectly useless to me. Good trade. Quote Link to comment
85NAPSZ Posted June 24, 2010 Author Report Share Posted June 24, 2010 So, this is the driveshaft insulator thingy? Quote Link to comment
datzenmike Posted June 24, 2010 Report Share Posted June 24, 2010 Yes the rubber part that is clamped down with the U shapped strap. Quote Link to comment
Suspect Posted June 24, 2010 Report Share Posted June 24, 2010 I used a couple strips of serpentine belt and zip tied them on the bottom of the bearin, (zip tied to the bearing brace)... That lasted about 20k so far, on my 77 I end up buying a new bearing from autozone. it is still available until they run out completely. http://www.autozone.com/autozone/parts/Dea-Driveshaft-Center-Support/1977-Nissan-Datsun-620/_/N-indtxZ6o20v?counter=1&filterByKeyWord=center+&fromString=search&itemIdentifier=714417_8915_0_ Quote Link to comment
kdennis Posted June 24, 2010 Report Share Posted June 24, 2010 https://www.powertrainindustries.com/catalogs_type.htm?type=Center+Supports Quote Link to comment
240ADAM Posted June 24, 2010 Report Share Posted June 24, 2010 Just get a stock 510 wagon driveline. It bolts right in, then you never have to worry about the carrier bearing again. I used one on my 75 620 with a 4 speed. worked like a charm. Oops I just saw you have a 720 , but its woth a shot. Quote Link to comment
85NAPSZ Posted June 24, 2010 Author Report Share Posted June 24, 2010 That would work if I could get my hands on one around here. I've seen more Ferarris here than Datsuns. Quote Link to comment
