Trex72 Posted May 26, 2010 Report Share Posted May 26, 2010 need to know what alternator to get from rock auto. need a l20b 60 amp internally regulated if possible the engine is from a 1975 620 pu . Quote Link to comment
banzai510(hainz) Posted May 26, 2010 Report Share Posted May 26, 2010 YOu can figure this out yourself. k the model yr and if they list a voltrage on the side then you know its external. If the model yr dont list a volt reg then you can assume its a Internal VR. But the cutoff is usaully around late78 79 when they started to go Internal VR alternators. PS a 50/60 amper alt in a truck needs soem modes as most trucks I seen have the smaller 35amper. cause the alternator case is Bigger in the 50/60 ampers it can hit the ilder arm mount on the fram and cant get full adjustment/makes noise rattling on the idler arms Quote Link to comment
datzenmike Posted May 26, 2010 Report Share Posted May 26, 2010 YOu can figure this out yourself. k the model yr and if they list a voltrage on the side then you know its external. If the model yr dont list a volt reg then you can assume its a Internal VR. But the cutoff is usaully around late78 79 when they started to go Internal VR alternators. PS a 50/60 amper alt in a truck needs soem modes as most trucks I seen have the smaller 35amper. cause the alternator case is Bigger in the 50/60 ampers it can hit the ilder arm mount on the fram and cant get full adjustment/makes noise rattling on the idler arms X2 on this. '78 and up had internal regulators. In order to fit you need the smaller 35 amp 620 alt. IF yours was converted to internal regulated 60 amp then any '80-'86 720 truck or '80-'83 200sx will work. Quote Link to comment
Trex72 Posted May 26, 2010 Author Report Share Posted May 26, 2010 the motor is in a 510 not a 620 pu and i need more amps to push extra lights ,radio and a computer hook up .will the internal 60 amp from a 80-86 pu fit in my 510 that has a l20b in it? ty . Quote Link to comment
banzai510(hainz) Posted May 26, 2010 Report Share Posted May 26, 2010 datsun 610s I dont know what year started having External reg 50amp alternator from there up had the 50/60 ampers in the cars Yes 510s have more room and the mounts are pretty much the same. even up to the KA alternators(just have different connector instead of the T connector. youll need to do the jumpers at the voltReg connector if you havent dont them already. Datzenmike shows this and a few other people. Quote Link to comment
Trex72 Posted May 26, 2010 Author Report Share Posted May 26, 2010 Thanks fellas great info RATSUN rocks ! 1 Quote Link to comment
zerow Posted May 26, 2010 Report Share Posted May 26, 2010 datsun 610s I dont know what year started having External reg 50amp alternator from there up had the 50/60 ampers in the cars Datsun 610s all had 50 Amp Alternators standard, the 60 Amp was an "upgrade" You can ask for the "upgraded 60 Amp alternator" at the counter when ordering. Quote Link to comment
Unclejesse88 Posted May 27, 2010 Report Share Posted May 27, 2010 I just installed a 2004 KA Frontier alternator on my l16 in the 510. Aside from building a conversion pigtail, and drilling out the lower mount for the 10mm bolt, it's a direct bolt in. It is 70 amps. I did also upgrade the charge wire and fusible link at the same time. Quote Link to comment
datzenmike Posted May 27, 2010 Report Share Posted May 27, 2010 Datsun 610s all had 50 Amp Alternators standard, the 60 Amp was an "upgrade" You can ask for the "upgraded 60 Amp alternator" at the counter when ordering. This is true. Going up 10 amps is a waste of time. My 710 had external regulator and I had a 60 amp internal regulator (IR) from an '80 200sx perfect fit mo mods what so ever to the mount or belt. I'm used to the 620 35 amp and didn't know the 510/610/710 already had a 50 amp alt., so really I was just up grading to IR. As it turned out it was no good so a had a spare 720 (60 amp) IR (also a perfect fit) and it worked for a day. :angry: Lucky third try was modifying a 240sx KA 80 amp alt to fit. Very happy with it. Reads 14.7 volts with high beams on at idle, heater does not speed up and down with the signal flashers. Quote Link to comment
Trex72 Posted June 19, 2010 Author Report Share Posted June 19, 2010 just got a 60 amp ir alternator now how do you hook this thing up to where the old voltage regulator was hooked up ? pics or a diagram would be awesome ! Quote Link to comment
datzenmike Posted June 19, 2010 Report Share Posted June 19, 2010 Ask and... You must disconnect the old regulator and not use it. I used the external regulator plug, cut all wires off 2" long, removed all but the four that need to be jumpered together. Bared the wires and soldered he white/black and white/red together and the yellow and white and sealed with heat shrink tubing. Now the jumpers are on the old plug and you just connect it to the main harness. Neat, secure and no bare loose taped up wires to cause problems later. Regulator plug with spade connectors removed ready for cutting. Finished plug with jumper wires put back in position. . Quote Link to comment
Trex72 Posted June 20, 2010 Author Report Share Posted June 20, 2010 really struggling with this do not have the old plug ! do you have any pics of it installed and where the wires go from the new plug ? ty . Quote Link to comment
banzai510(hainz) Posted June 20, 2010 Report Share Posted June 20, 2010 dude this is EZ. remove the old volt reg connector.the engine harness connecotrs will be female make 2 jumper wires with male blade connectors on there. 1/2in to 1 in long. now stick it in the female connector wht/red will jumper to the wht blk yellow jumpered to the white. Mike was just showing you another way using the old Volt reg side of the connector to accomplish the same thing. If in dought then dont do it I reread your post you say you dont have the volt reg connector. Where is it? Or is this car already converted. Soul Sounds like the car is converted already and just order a 78/79 Z car alternator Quote Link to comment
Trex72 Posted June 20, 2010 Author Report Share Posted June 20, 2010 got it !I have other electrical problems it seems . Quote Link to comment
