Kevin S. Posted May 22, 2010 Report Share Posted May 22, 2010 Well thanks for all the help and advise. I found some belting off a machine at work.... It was about a half an inch thick... Cut it into strips about 1.5 inches wide and long enough to wrap around the bearing, cut it approximatley every 1/2 of an inch so it would flex nicely. I cleaned the metal and applied a thin layer of the adhesive. wraped it, taped it to keep it in place. After it dried I applied a second coat of the sticky stuff and wrapped the belting and retaped. It fit perfectly!!!! When I put it in the bracket it had 1/4 of an inch of space... So when tightened down it is tight and squished the new bushing!!! Now the driveline is well supported and will not flop around at all!!!!! It was hella easy!!! I HOPE THAT IT HOLDS UP!!! When I can figure out how to post some pics I will get them up. Quote Link to comment
datzenmike Posted May 22, 2010 Report Share Posted May 22, 2010 How to post pictures on line 1 Quote Link to comment
Kevin S. Posted May 22, 2010 Author Report Share Posted May 22, 2010 First pic. Second pic. LAter I will send pics of my truck!!! Thank you for the help!!!! 1 Quote Link to comment
74datsun620 Posted May 23, 2010 Report Share Posted May 23, 2010 Very cool!!!!!!!! Quote Link to comment
Gary Posted May 23, 2010 Report Share Posted May 23, 2010 nice one man mines busted too, the only way i think to fix is to replace whole center bearing for lots of money will be hitting up something similar :D Quote Link to comment
Greiggy Posted May 23, 2010 Report Share Posted May 23, 2010 nice one man mines busted too, the only way i think to fix is to replace whole center bearing for lots of money will be hitting up something similar :D gary i have a spare one here if your interested ... 20 bucks inc the freight and its yours... Quote Link to comment
