zerow Posted May 10, 2010 Report Share Posted May 10, 2010 I am looking for build diagrams or working drawings of the Jatco 3N71B and L4N71B transmissions for comparison. Scale does not matter, as long as it is dimensioned. I am sure someone knows of one or has something on microfilm somewhere. I am always doing drafting work, I guess its how my mind works. I need relative heights and widths as well as distances from the centerline so I can make absolutely sure I have everything compensated for on my transmission swap (my 610 came with the 3N71B, and I am swapping in the L4N71B for the overdrive capability). Post what you've got, I will be happy to look at everything. I already ran into one problem with the mounting, just want to ensure that this is the last and only hitch before I get underway. Better to do it right once, instead of messing up a bunch of driveline parts in the process of performing this swap. Quote Link to comment
datzenmike Posted May 10, 2010 Report Share Posted May 10, 2010 L4N71B top and 620 3N71B below. . It's about an inch longer than the 610 tranny. . Quote Link to comment
zerow Posted May 10, 2010 Author Report Share Posted May 10, 2010 L4N71B top and 620 3N71B below. . It's about an inch longer than the 610 tranny. . Thanks Datzenmike. I am looking for the distance between the mount heights (vertically) between the two transmissions; Most notably, the difference between the stock mounting point on the 3N71B and the "ears" at the rear of the L4N71B Without a total mockup, I want to see the difference (if any) in heights. The adaptor I have drawn will depend on that difference in height. Quote Link to comment
mklotz70 Posted May 10, 2010 Report Share Posted May 10, 2010 check olddatsuns.com's tech page....I'm pretty sure I put up the automatic's manual on there...it will be toward the bottom of the list. The manual trans may be in one of the vehicle manuals. Quote Link to comment
zerow Posted May 10, 2010 Author Report Share Posted May 10, 2010 check olddatsuns.com's tech page....I'm pretty sure I put up the automatic's manual on there...it will be toward the bottom of the list. The manual trans may be in one of the vehicle manuals. Thanks mklotz70. I checked the site, but it just gives me the general information about the transmission, not specific dimensions between casted parts. I will keep hope alive with this one, otherwise, it will be trail and error (hopefully not to many errors...) Quote Link to comment
