Dimenz Posted May 2, 2010 Report Share Posted May 2, 2010 on Ebay... http://cgi.ebay.com/ebaymotors/DATSUN-510-BLUEBIRD-COUPE-SSS-REAR-LIGHTS-RELAY-/180502415951?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item2a06c84a4f Link to comment
MicroMachinery Posted May 2, 2010 Report Share Posted May 2, 2010 Publicly announcing anything like this really makes it hard for people without much money to win the bid on such a sought after item. There goes my chance to win.. <_< Link to comment
RadioLobo Posted May 2, 2010 Report Share Posted May 2, 2010 Next time you see some for sale tell me and me only :P Ive also been looking for a set, but i always get outbid :( Link to comment
78kingcab Posted May 4, 2010 Report Share Posted May 4, 2010 shit i just ran it up to 400.00.....and still has reserve.....thanks for posting it id missed it :) are these your lights dimenz........i noticed your both from n.j. Link to comment
SSS510 Posted May 5, 2010 Report Share Posted May 5, 2010 The relay doesn't look like it's the correct one! But I might be wrong! Doesn't say Sequential Flasher and the plugs don't usually extend out that much.. 1 Link to comment
jefe de jefes Posted May 5, 2010 Report Share Posted May 5, 2010 I dont think it's the correct sequential relay either. I remember seeing pics of those installed on the passenger side kick panel of US sold 510's. Same one's?VV http://www.the510realm.com/viewtopic.php?f=10&t=11912&hilit=sequential&start=15 Link to comment
SSS510 Posted May 5, 2010 Report Share Posted May 5, 2010 I dont think it's the correct sequential relay either. I remember seeing pics of those installed on the passenger side kick panel of US sold 510's. http://www.the510realm.com/viewtopic.php?f=10&t=11912&hilit=sequential&start=15 YEA That relay doesn't look right at ALL!!! Cause I've seen the single one and looks nothing like that at ALL!!! 1 Link to comment
inline4 Posted May 5, 2010 Report Share Posted May 5, 2010 that relay is a smog equip relay I think. Link to comment
MicroMachinery Posted May 5, 2010 Report Share Posted May 5, 2010 Bad business... <_< Link to comment
sssr20det510 Posted May 5, 2010 Report Share Posted May 5, 2010 that relay is a smog equip relay I think. I think its for an auto tranny Link to comment
SSS510 Posted May 5, 2010 Report Share Posted May 5, 2010 Wow!! How many sets you got! ANY SINGLE SEQUENTIAL FLASHER'S?? :thumbup: YES THESE ARE THE CORRECT ONES!! 1 Link to comment
Yakuza Posted May 5, 2010 Report Share Posted May 5, 2010 the 1 in the set with lights on ebay is the wrong 1...its for automatic car sits on the passenger side kick panel... 1 Link to comment
hang_510 Posted May 5, 2010 Report Share Posted May 5, 2010 The relay doesn't look like it's the correct one! for someone currently using these lamps w/the sequencer: would the flasher unit from an early mercury cougar work? ive thought about changing in the lamps from the 66... but something isnt quite right (besides being ford) "The following article was performed on a Mercury Cougar although the equipment used will work on any model vehicle that has a 2 to 4 bulb tail light system that you want a sequential turn signal installed." http://www.lovefords.org/tech/jefflilly/sequential.html Link to comment
qwik510 Posted May 6, 2010 Report Share Posted May 6, 2010 for someone currently using these lamps w/the sequencer: would the flasher unit from an early mercury cougar work? ive thought about changing in the lamps from the 66... but something isnt quite right (besides being ford) "The following article was performed on a Mercury Cougar although the equipment used will work on any model vehicle that has a 2 to 4 bulb tail light system that you want a sequential turn signal installed." http://www.lovefords.org/tech/jefflilly/sequential.html The cougar didn't come out until 1967. I used to have a 68 cougar. The 66 T-Bird used the same sequential box. The cougar sequential box might work but they are getting hard to find and expensive and they are a mechanical setup. The newer electronic versions work better. My friend Vince just installed these: Only $69 for the pair. Solid State Circuitry Self-Adjusting Electronics assures Perfect Sequencing Action! Programmable Brake Light Operation Works on All Multiple Signal Cars Works with LEDs or Standard Bulbs If you have two or more turn signal filaments on each side of your car, you can add the STS-1, STS-2, or STS-4 Sequencer Kit and really indicate your intentions. These modules feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, our modules sense your car's flasher speed and adjust the 1-2-3 sequence timing for you. Want more separation between individual lamps? Just put in a slower flasher! If your car has combination stop/turn signal lamps, these modules will sequence the turn and emergency flashers only. The brake lights operate normally! However, if you also want a single brake light sequence (called "brake light burst"), these modules will do it. Your Choice! Installation takes about an hour, and for most cars, only basic hand tools are required! Qty STS-1 Sequential Turn Signals, $69 .......... - For cars with 3 lamps on each side More info here: http://www.webelectricproducts.com/products.htm 1 Link to comment
jefe de jefes Posted May 6, 2010 Report Share Posted May 6, 2010 The cougar didn't come out until 1967. I used to have a 68 cougar. The 66 T-Bird used the same sequential box. The cougar sequential box might work but they are getting hard to find and expensive and they are a mechanical setup. The newer electronic versions work better. My friend Vince just installed these: Only $69 for the pair. Solid State Circuitry Self-Adjusting Electronics assures Perfect Sequencing Action! Programmable Brake Light Operation Works on All Multiple Signal Cars Works with LEDs or Standard Bulbs If you have two or more turn signal filaments on each side of your car, you can add the STS-1, STS-2, or STS-4 Sequencer Kit and really indicate your intentions. These modules feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, our modules sense your car's flasher speed and adjust the 1-2-3 sequence timing for you. Want more separation between individual lamps? Just put in a slower flasher! If your car has combination stop/turn signal lamps, these modules will sequence the turn and emergency flashers only. The brake lights operate normally! However, if you also want a single brake light sequence (called "brake light burst"), these modules will do it. Your Choice! Installation takes about an hour, and for most cars, only basic hand tools are required! Qty STS-1 Sequential Turn Signals, $69 .......... - For cars with 3 lamps on each side More info here: http://www.webelectricproducts.com/products.htm That's a good deal! Thanks for sharing that qwik. Link to comment
Dimenz Posted May 6, 2010 Author Report Share Posted May 6, 2010 Bad business... <_< Did not know it was the wrong relay. I beleived it was the sequential flasher unit when I bought the lights (came with the lights)...Ebay listing cancelled due to error... Link to comment
qwik510 Posted May 6, 2010 Report Share Posted May 6, 2010 That's a good deal! Thanks for sharing that qwik. I thought they were a good deal. Since BB sequential boxes sell for $150-$200 each. Link to comment
hang_510 Posted May 6, 2010 Report Share Posted May 6, 2010 The cougar didn't come out until 1967. I used to have a 68 cougar. The 66 T-Bird used the same sequential box. i know that the 67 has the lens angled in, im thinking of the year that lens angles out??? good info! thanks! Link to comment
hang_510 Posted May 6, 2010 Report Share Posted May 6, 2010 Ebay listing cancelled due to error... :thumbup: good business! Link to comment
SSS510 Posted May 6, 2010 Report Share Posted May 6, 2010 Did not know it was the wrong relay. I beleived it was the sequential flasher unit when I bought the lights (came with the lights)...Ebay listing cancelled due to error... You should have just stated on the auction that the relay was not correct to the taillights.... Link to comment
