  • Replies 16
Are you sure it's an L18??? Check the flat spot behind the dip stick handle. The motor size is stamped there.
Two things....
One.. The W58 head was used on L20B motors usually from '78 on. (could have been swapped)
Two... it has a matchbox dizzy on it. (could have been swapped I guess, but would have been on any '79 and up L20B motor too.
Three... some emission stuff has been mismatched from possible motor swap.
Two things....
four It was in the 521 inthe pic, bolted to a "79 frame (swapped}
If that is an L20 Scott, let me know if Awaysshocking is not interested.
Good luck.
Funny; I kept watching this post to see if you sold it yet. I should have noticed the disk brakes and front sus. in your last picture.
