metalmonkey47 Posted April 6, 2010 Report Share Posted April 6, 2010 So to keep it simple, my dash lights don't work. I pulled the dash and applied 12volts to the correct part of the socket where the harness plugs into the dash and I get full light. The weird thing is those two sockets ARE getting 12volts so why aren't my gauges working? I checked the harness and I have 12volts at the green/yellow and green/white to ground. I've tried two different rheostat's and I still have no light. Now, I think it's very strange that the g/y and g/w BOTH have 12volts. One should be negative right? ALSO the shithead that I bought to car from tried to hide an electrical problem with the car by removing the light that illuminates the voltage indicator. I put a bulb in and the fucker lit up. Not very bright though.. Anyways.... Help? Quote Link to comment
Str8_69 Posted April 6, 2010 Report Share Posted April 6, 2010 Funky... try a headlight switch? Not familiar with the B310, is the rheostat part of that switch, or independent? Quote Link to comment
metalmonkey47 Posted April 6, 2010 Author Report Share Posted April 6, 2010 Funky... try a headlight switch? Not familiar with the B310, is the rheostat part of that switch, or independent? Tried that =/ The rheostat is the dimmer located on a separate harness. 3 wires to it; G/W, G/Y, and Black.. G/W and G/Y have 12volts. Black is negative/ground. Quote Link to comment
zerow Posted April 6, 2010 Report Share Posted April 6, 2010 Tried that =/ The rheostat is the dimmer located on a separate harness. 3 wires to it; G/W, G/Y, and Black.. G/W and G/Y have 12volts. Black is negative/ground. I don't know if it is like a 610, but there is a little voltage regulator that "helps" with the dimming process. Its a little box on the back of the dash cluster. (When and If) It goes out, it takes the dash lighting down with it. Confirm before tossing the whole thing <=> re-ground the wire for the rheostat. If found to be bad, root cause found. If no change, two grounds are better than one. Quote Link to comment
DanielC Posted April 6, 2010 Report Share Posted April 6, 2010 If it is just a simple rheostat, with only two wires going to it, and you hook up a volt meter only to the "output" of the rheostat, the volt meter will not drawe enough current through it to cause a voltage drop. Quote Link to comment
metalmonkey47 Posted April 6, 2010 Author Report Share Posted April 6, 2010 Well this one has 3 wires to it. two have 12volts, however I don't think that they both are supposed to have 12volts. So what your saying is that one is an input, and the other is an output? Quote Link to comment
