Datsun Parts Posted April 2, 2010 Report Share Posted April 2, 2010 If anyone has any L16-L20B Oil Pan Pick Up Tube Screens I am in need of 2. I also need two L24 or L28 oil pans and oil pump gear drives. Thanks! Quote Link to comment
hang_510 Posted April 2, 2010 Report Share Posted April 2, 2010 i may have the p/u's. ill look for you over the weekend. no drive spindles (i could use 1 myself) Quote Link to comment
datzenmike Posted April 3, 2010 Report Share Posted April 3, 2010 Dizzy/oil pump spindles for the L16/18/20B/24/26/28 are the same. Quote Link to comment
HRH Posted April 4, 2010 Report Share Posted April 4, 2010 You don't have any drive spindles at the local wrecking yard u pull it down in CA? Four bolts on the pump and away you go with the spindle. Takes like 2 minutes. I probably have some in the garage if you're still looking for them. Send me a pm if you are. Quote Link to comment
hang_510 Posted April 5, 2010 Report Share Posted April 5, 2010 Four bolts on the pump and away you go with the spindle. Takes like 2 minutes. the stuff ive seperated are usually rusted :angry: i will need another, but for now im good. just another shiny spare would be good. i found out my comp pan doesnt allow for the windage tray w/the Z24 crank <_< fortunately the other pans windage tray might fit. so... while doing all this, i forgot to look for your p/u's :huh: maybe well trade for a spindle? :) Quote Link to comment
