slinginabullet Posted March 9, 2010 Report Share Posted March 9, 2010 So I've tryed doing a search but not the results I'm looking for :( Does anyone know of or have any info on this I've talked to my cousin but my phone was dying. I will try to go this direction before complete chassis re modification which might happen anyway. Quote Link to comment
72240z Posted March 9, 2010 Report Share Posted March 9, 2010 You would have to fab or have it completely fabbed up since the fronts are torsion bars and rears are springs. There is a guy on here who used a s13 suspension, forget his name, flat green 620 with an sr. Search on here you'll find him. Quote Link to comment
ariascarlos1990 Posted March 9, 2010 Report Share Posted March 9, 2010 Doesn't bebani sell brackets for this? Quote Link to comment
slinginabullet Posted March 9, 2010 Author Report Share Posted March 9, 2010 that's the truck I was looking for I've seen once on here couldn't find his tread angain :unsure: My cousin was telling me bebani sold some kind of kit I need to ask him what this kit in-tails? Quote Link to comment
ariascarlos1990 Posted March 11, 2010 Report Share Posted March 11, 2010 that's the truck I was looking for I've seen once on here couldn't find his tread angain :unsure: My cousin was telling me bebani sold some kind of kit I need to ask him what this kit in-tails? http://community.ratsun.net/topic/15875-chadcopelandcom-620-build/ Quote Link to comment
Guest DatsuNoob Posted March 11, 2010 Report Share Posted March 11, 2010 You could beef up the stock front shock mount and drill it for a clevis style mount like I plan on doing. It would be very important to weld in some gussets to the frame to tie it all together since the orig design was meant to carry the load through the tortion bar, not the shock mount as previously stated. Part number for QA1 coilovers to fit are either #3855 or #4855, cant remember right now. Check out Fineline's build and you'll see what I'm talking about.That would be the easiest rout to sort out the front IMO.`Good luck dude Quote Link to comment
BEEBANI Posted March 11, 2010 Report Share Posted March 11, 2010 I'm working out a kit for the 4855's right now (stay tuned for a new project thread on a kc I have at my house right now) because they are 14" center to center. The Coils that I set up my kit with were quite a bit shorter. The kit entails the upper/lower brackets, hardware, and a template for cutting the upper shock mount for the new bracket to be welded to. Quote Link to comment
Guest DatsuNoob Posted March 11, 2010 Report Share Posted March 11, 2010 I'm working out a kit for the 4855's right now (stay tuned for a new project thread on a kc I have at my house right now) because they are 14" center to center. The Coils that I set up my kit with were quite a bit shorter. The kit entails the upper/lower brackets, hardware, and a template for cutting the upper shock mount for the new bracket to be welded to. I had planned on doing this thing myself, but I got other major areas of the build to focus on if I'm gonna make Canby (counting the weeks!:hyper:). What do you think you'd ask for them? Thanks Jason Quote Link to comment
slinginabullet Posted March 12, 2010 Author Report Share Posted March 12, 2010 Thanks for the info guys. :thumbup: Quote Link to comment
BEEBANI Posted March 12, 2010 Report Share Posted March 12, 2010 I had planned on doing this thing myself, but I got other major areas of the build to focus on if I'm gonna make Canby (counting the weeks!:hyper:). What do you think you'd ask for them? Thanks Jason I dunno, I usually $100 for everything on the other ones, so that should work. Not sure, but they will be very similiar to the ones I make for the shorter springs. Quote Link to comment
Guest DatsuNoob Posted March 12, 2010 Report Share Posted March 12, 2010 PM me when you get all the details worked out. I might pick up a set if I'm short on time. I really wanna get down to Canby on coilovers and discs instead of bars and drums. Quote Link to comment
slinginabullet Posted March 26, 2010 Author Report Share Posted March 26, 2010 If you ship I'll get a set also. I found a universal kit for rear springs to coil overs Click Here cut to fit and paint to match Quote Link to comment
]2eDeYe Posted March 26, 2010 Report Share Posted March 26, 2010 You'll need to get a 3-link or 4-link setup as well to go with that kit. Quote Link to comment
slinginabullet Posted March 27, 2010 Author Report Share Posted March 27, 2010 Nothing wrong with that :) most likely a 4 link a 3 link seems like it might get in the way of running gear? besides can't you do more adjustments with a 4 link anyway? Quote Link to comment
slinginabullet Posted April 18, 2010 Author Report Share Posted April 18, 2010 So I've been thinking and taking measurements if you build a mount from the existing location were the top of the front shocks go it looks like you could slide in a coil over and bolt right up in replacing the factory shocks it's kinda tight but with the right coil over it should work Quote Link to comment
BEEBANI Posted December 14, 2010 Report Share Posted December 14, 2010 I have the kc brackets all worked out and ready to weld up. The only problem with this set up is the stock sway bar will not bolt right up with the coilovers in there. You'll need to figure out a different end link setup for it. Quote Link to comment
