jeepinjakear15 Posted March 1, 2010 Report Share Posted March 1, 2010 Hi everyone I have a 1965 l-320 that is gonna needs points and a coil etc but i do not believe the engine came with it the engine code is J15382960 if anyone can help me source this stuff it would be great! windshield would be rad too Quote Link to comment
banzai510(hainz) Posted March 1, 2010 Report Share Posted March 1, 2010 PM (Mklotz )on here he has a 320 .Im sure he knows for sure but will assume its a high resistance and a ballast system. Quote Link to comment
datsunaholic Posted March 1, 2010 Report Share Posted March 1, 2010 Well, it depends on the engine... It's obviously not original as a '65 320 would have had an E1 engine. The question is the serial number... does it say "J 15382960", or "J15 382960". I'm assuming the latter. So then it matters what distributor it has. Most likely, it will need points that match a 1968 521 (although that's not what the engine is from if the numbers are the latter, but the J15 was never used in the US) but that's a close match. But if it has the original 1965 dist, then you need points for that. Coil, you just need a standard points-type coil. Quote Link to comment
jeepinjakear15 Posted March 2, 2010 Author Report Share Posted March 2, 2010 yea it says on the lower part J15 then on the upper flatspot are the rest of the numbers how do i tell what distributor i have? and should i change the points to electronic? Quote Link to comment
jeepinjakear15 Posted March 2, 2010 Author Report Share Posted March 2, 2010 hi everyone i have a datsun l-320 that had a bad fuel tank. I took it to a place and they coated it inside and out and fixed the holes. I have the original sending unit and it seems to give me a different ohms reading as i cycle the float so i assume its working correctly. but when i hook it up and do that the gas gauge does not move. Is it common for these to go out? and whats the easiest way to access the back of the fuel gauge on a 320? Quote Link to comment
jeepinjakear15 Posted March 2, 2010 Author Report Share Posted March 2, 2010 anyone know much about these heater setups? and i am missing the peice of duct work that goes from the sqirrel cage opening to the top vent controller anyone know where one can be sourced? Quote Link to comment
jeepinjakear15 Posted March 2, 2010 Author Report Share Posted March 2, 2010 anyone redone their electrical system with like a universal painless setup with the newer style atc fuses? ive seen some debate on the gm 1 wire alternator and that its not a good choice, does anyone have any great insight for me on mounting and what one to go with? sorry for all the questions i just wanna get the thing driving I have lusted after it since i was 16 and finally bought in december! Quote Link to comment
jeepinjakear15 Posted March 2, 2010 Author Report Share Posted March 2, 2010 hey sorry in advance for all the questions but i was hoping you guys could help anyone know of a source for a new front windshield from what ive been told im pretty much screwed. Quote Link to comment
jeepinjakear15 Posted March 5, 2010 Author Report Share Posted March 5, 2010 http://www.facebook.com/Jacob.Hilliard?v=app_2392950137#!/video/video.php?v=343844589515 Quote Link to comment
banzai510(hainz) Posted March 5, 2010 Report Share Posted March 5, 2010 "HRH" on here lives in Spokane Im sure he could help you. Quote Link to comment
jeepinjakear15 Posted March 5, 2010 Author Report Share Posted March 5, 2010 yeah spokane is like 90 miles away from where i live Quote Link to comment
Charlie69 Posted March 8, 2010 Report Share Posted March 8, 2010 Pictures Where? Quote Link to comment
