zerow Posted February 28, 2010 Report Share Posted February 28, 2010 (I Originally posted this in the tension control rods thread, but Inquiring Minds Want To Know) Okay, so I'm going for the full front end rebuild. I have the ST poly bushings. My 610 will be primarily a street driven (long distances on occasion) car. The drilling as described in the tension control rod thread (see below) - does it work, or is that a band-aid for a problem down the road? The Dime Quarterly had an article showing the proper way to modify poly bushings. http://www.dimequarterly.tierranet.com/articles/tech_tcrod.html Tension / Compression Rod Modification A simple modification may help prevent T/C rod failures Article and Illustrations by Kelvin Dietz One of the most noticeable changes you can make to your car's handling is to replace the old rubber suspension bushings. By now they are well past their useful life and should probably be replaced. This was all covered in a previous DQ article, and one of the recommendations was to replace the stock Tension/Compression (T/C) rod bushings with Energy Suspension polyurethane bushings. For a street driven or an autocross/street car, I think this is the best option. Parts are easy to come by, simple to install and maintenance free. However, I found an unpleasant side effect from these bushings that I thought I would share. On a recent trip across town, I experienced the failure of my passenger-side T/C rod. I hit a small bump, heard a pop and noticed a slight pull to the right, but didn't think much of it as the car still went FAIRLY straight. I drove the car home and took the wheel off to find the problem. I nearly had a heart attack when I noticed the T/C rod had snapped in half at the shoulder behind the bushing. Not a problem at 30 M.P.H. on a city street, but potentially VERY damaging on a tight lefthander at 60 mph. I'm surprised we haven't heard of more failures like this. Even though I've attempted to restore the stock front control arm angle by using bumpsteer spacers, my T/C rods are still angled up in comparison to stock. Between that and the stiffer bushings, the T/C rods experience much more stress than they do at stock ride height. In light of this experience, I suggest modifying the polyurethane T/C bushings. I drilled six 5/16" holes around the perimeter of the center mounting hole. These should allow the T/C rod to pivot more easily and still offer the advantage of the stiffer bushing when braking and/or cornering. I recently replaced both of my T/C rods with a set from a car that had never been lowered. I also had that set Magnifluxed to be sure they were still in good shape. I shudder to think of the consequences of a high-speed failure. DQ Rubber is better, I get that, but, are they still available? and I don't mean available on a shelf, and the rubber is harder than poly. I will be getting underway soon, like next month, so I want to know that if drilling is the answer, and I won't run the risk of shattering, breaking or stressing if I do the drilling as prescribed. Or go and get the rubber bushings and alleviate one worry from future driving. Quote Link to comment
INDY510 Posted February 28, 2010 Report Share Posted February 28, 2010 I got some nice soft ones at the local parts store a few years ago,, .. .. just asked for stock 68-73 510 T/C rod bushings..... I broke a T/C rod 6 years ago because of poly bushings from the 80's...... and then I tried the Carrol "ball and cup" idea. 710 and 510 T/C rods are identical,,, (maybe the same for 610's?)..... if you have $200 to throw at your car,,, .. try these: Quote Link to comment
datzenmike Posted February 28, 2010 Report Share Posted February 28, 2010 710 and 610 TC rods are the same part number. Quote Link to comment
Skib Posted February 28, 2010 Report Share Posted February 28, 2010 with S30/S130's we just run one rubber and one polly so its got that room to flex (and not break/bend sending you vearing off to one side) Quote Link to comment
zerow Posted February 28, 2010 Author Report Share Posted February 28, 2010 I got some nice soft ones at the local parts store a few years ago,, .. .. just asked for stock 68-73 510 T/C rod bushings..... I broke a T/C rod 6 years ago because of poly bushings from the 80's...... and then I tried the Carrol "ball and cup" idea. 710 and 510 T/C rods are identical,,, (maybe the same for 610's?)..... if you have $200 to throw at your car,,, .. try these: These are nice - where would someone like me get those for the $200 you mention? Quote Link to comment
INDY510 Posted March 1, 2010 Report Share Posted March 1, 2010 . http://www.ermish-racing.com/510/tcrods.html Quote Link to comment
