salinas2tone510 Posted February 24, 2010 Report Share Posted February 24, 2010 Hey how is everyone, my name is Israel and i have a 510 project im working on. I heard great and interesting things about ratsun and i decided to become a member =) unfortunately when you start on a project you always experience a conflict =( I have a conflict.... and its my proportioning valve... I cant find one, but somebody said a universal and adjustable one might do the job? I would appreciate any help from someone, i have to get my dime on the road again =( its my daily driver..... Quote Link to comment
hang_510 Posted February 24, 2010 Report Share Posted February 24, 2010 its not a proportioning valve, its a distribution 'valve'. someone here should have a used avail. Quote Link to comment
jonesy510 Posted February 25, 2010 Report Share Posted February 25, 2010 ummm.... pics :D ;) haha sorry i cant b much help with ur conflict.... but sense ur new here i would love to see a pic of ur ride haha Quote Link to comment
Icehouse Posted February 25, 2010 Report Share Posted February 25, 2010 Welcome to the board! :) If it's your daily driver what happened to the one on it? There really isn't much in there to go bad. Quote Link to comment
salinas2tone510 Posted February 25, 2010 Author Report Share Posted February 25, 2010 does anyone know where i can get one for my 510....... or does anyone have a good one for sale? thanks =) oh and il post some pics soon for those who want to check out my dime =) Quote Link to comment
salinas2tone510 Posted February 25, 2010 Author Report Share Posted February 25, 2010 The thing is that my front brakes are freezing on me when i drive.....so i took my car to a mechanic and he said its the distribution valve.I had the problem with the stock 510 disc and calipers...now i have 280zx struts with the complete assembly, new 510 master cylinder, new brakes, new brake lines,new calipers,and its still doing the same thing ! Its driving me nuts so i would appreciate some help =( thanks all. Quote Link to comment
180Bsss Posted March 1, 2010 Report Share Posted March 1, 2010 does anyone know where i can get one for my 510....... or does anyone have a good one for sale? thanks =) oh and il post some pics soon for those who want to check out my dime =) a israel say no more i have 1 for you 4free hahahaha i just finished slapping my L20 together almost ready for ginos swap meet ill go check how much is it to ship it to you tomorrow distribution 'valve' L20 Quote Link to comment
thisismatt Posted March 1, 2010 Report Share Posted March 1, 2010 That's 99.9% not likely to be your problem. Your problem is more likely to be that your master cylinder push rod is adjusted too far in to your master cylinder, which doesn't allow residual braking pressure to release after pushing on the brakes, and just becomes worse the more you drive due to heat expansion of the brake fluid. Check the push rod and make sure there is a little free-play before it starts pushing on the master cylinder piston. Quote Link to comment
Icehouse Posted March 1, 2010 Report Share Posted March 1, 2010 That's 99.9% not likely to be your problem. Your problem is more likely to be that your master cylinder push rod is adjusted too far in to your master cylinder, which doesn't allow residual braking pressure to release after pushing on the brakes, and just becomes worse the more you drive due to heat expansion of the brake fluid. Check the push rod and make sure there is a little free-play before it starts pushing on the master cylinder piston. Matt I think your close but I think the problem is he put a newer master out of a rig with a booster where the rod doesn't actually clip into the master like the 510 unit. If you use the 510 rod with retaining washer in the newer master the thickness of the retaining washer is enough to do exactly what you are saying. But instead of holding residual pressure with the rod it holds it with the washer. I've made that mistake a few times :) We always sharpen the pushrod without using the retaining washer that is built into the 510 push rod. Not a perfect fix but it seems to work fine. Quote Link to comment
Icehouse Posted March 1, 2010 Report Share Posted March 1, 2010 distribution 'valve' When you get it take it apart and look inside. All it does is equal out the pressure front to back and if either the front or rear system fails the piston slides to one side triggering the dash light. Quote Link to comment
thisismatt Posted March 3, 2010 Report Share Posted March 3, 2010 So, how are things working out? Quote Link to comment
