Dented front end on 620?
sick620
  • Replies 7
Guest DatsuNoob
I use the ghetto stud gun method. I grind the tips off 16d nails, put em on with me welder, then pull them shits out with my slide hammer. The trick is to go slow, and pull from different spots evenly to relieve the stresses in the panel. It will work, I do it all the time. Just dont go too fast or there is potential to tear the steel. You may not get it perfect, but you'll get 'er ruff enuff ;)
