cbattey224 Posted February 4, 2010 Report Share Posted February 4, 2010 hey guys need a flywheel to put the car on the road. im in socal Link to comment
datzenmike Posted February 5, 2010 Report Share Posted February 5, 2010 Any 5 bolt L16/L18 200mm will fit. Link to comment
NICOYA Posted February 5, 2010 Report Share Posted February 5, 2010 Any 5 bolt L16/L18 200mm will fit. 200mm = in inches plz i may have one i'll look one tomorrow and post some pic thanks Link to comment
NICOYA Posted February 5, 2010 Report Share Posted February 5, 2010 40.00 shipped if i have the 200mm= ? inches Link to comment
datzenmike Posted February 5, 2010 Report Share Posted February 5, 2010 Nissan is all metric. So get used to it. 200 is way easier than saying 7 7/8ths" If the 240mm is 9 29/64ths" QUICK! what's the difference between the two. If you use metric it's easy to see that it's 40mm. Lets see 9 29/64ths minus 7 7/8ths.... hmmmmm???????? :D Link to comment
420n620 Posted February 5, 2010 Report Share Posted February 5, 2010 NICOYA, here's a link for ur future references... ;) http://www.alcula.com/convert.php?cat=length&from=inch&to=millimeter Link to comment
ppeters914 Posted February 7, 2010 Report Share Posted February 7, 2010 Nissan is all metric. So get used to it. 200 is way easier than saying 7 7/8ths" If the 240mm is 9 29/64ths" QUICK! what's the difference between the two. If you use metric it's easy to see that it's 40mm. Lets see 9 29/64ths minus 7 7/8ths.... hmmmmm???????? :D ...and no one refers to metric parts with SAE measurements. Communications, man, communications.... :cool: Link to comment
