Sparks Posted January 30, 2010 Report Share Posted January 30, 2010 my dad is looking for the bracket that is bolted to the lower control arm on his 79 kingcab. we picked up a 77 parts truck with a complete front end but the brackets on the kingpin truck do not match up with the lower control arm on the 79. does anyone know where to find these brackets? thanks for the help. Quote Link to comment
Sparks Posted January 30, 2010 Author Report Share Posted January 30, 2010 the problem we are running into is that the angle of that bracket is different. the bracket from the 77 follows a deep bend from the lower control arm but the bracket on the 79 is much straighter. we have one bracket but need to locate another one. fabricating one wouldnt be too hard except for the grooved section where the torsion bar slides into the bracket. not having a welder available also makes trying to get the front done more difficult. Quote Link to comment
datzenmike Posted January 30, 2010 Report Share Posted January 30, 2010 Sorry, was thinking sway bar. Again the LCAs from '78 up are slightly different for the disc brake trucks. If it helps, the Nissan part # for the '78 and up torque arm... (that's the thing the torsion bar splines into and also bolts to the LCA) is 54080 B9500 for left or right side. About $50 at the dealer. Quote Link to comment
Sparks Posted February 2, 2010 Author Report Share Posted February 2, 2010 thank you for the help. ill get him to order the part. Quote Link to comment
Sparks Posted February 3, 2010 Author Report Share Posted February 3, 2010 called the dealer and searched around, no one seems to have this bracket. does anyone have one lying around that they would like to sell? Quote Link to comment
]2eDeYe Posted February 3, 2010 Report Share Posted February 3, 2010 There's a 79 at the Arlington Pull a Part. Quote Link to comment
Sparks Posted February 15, 2010 Author Report Share Posted February 15, 2010 looks like we have found a member with the part. should have the truck on the road shortly and we will be sure to add some pictures of our father and son datsuns. Quote Link to comment
sycloned916 Posted May 17, 2010 Report Share Posted May 17, 2010 Not to jack but what's the safe way to remove the torsion bars,I asked around and got different answers. Quote Link to comment
datzenmike Posted May 17, 2010 Report Share Posted May 17, 2010 Raise and support the side you want with the wheel off the ground. Find the anchors and loosen the top lock nut, then loosen both nuts of the anchor bolt. This will relieve all tension from the bar... Bleach said: How to Remove Torsion Bars in front of the middle crossmember, you pull the boot forward to reveal the lock ring Work a thin screwdriver into the edge of the ring. It will be tight. I had to work the angle back and forth while occasionally tapping the back of the handle with a hammer Once you get under the ring, work it out slightly. Do not pull the screwdriver away or the ring will pop back on After you have worked it off part way, use some pliers to pull the ring off the rest of the way. Be sure to still keep the screwdriver under the lock ring Tap the rear arm of that holds the adjuster bolt out of the crossmember. Hang onto the torsion bar. . Quote Link to comment
sycloned916 Posted May 17, 2010 Report Share Posted May 17, 2010 Raise and support the side you want with the wheel off the ground. Find the anchors and loosen the top lock nut, then loosen both nuts of the anchor bolt. This will relieve all tension from the bar... . Thank you. My buddy did his and said something flew out pretty good,I still move slow and don't want to get hurt. Thanks! Quote Link to comment
]2eDeYe Posted May 17, 2010 Report Share Posted May 17, 2010 Just make sure the suspension is unloaded and you should be good to go. Quote Link to comment
