sick620 Posted January 21, 2010 Report Share Posted January 21, 2010 what do i do with this Quote Link to comment
izzo Posted January 21, 2010 Report Share Posted January 21, 2010 It wont create a vacuum leak, you could just hook it up to the bottom of the air filter plate. I leave mine open as a lot do, or you can just get a tiny little filter on there some people prefer that. Quote Link to comment
ariascarlos1990 Posted January 21, 2010 Report Share Posted January 21, 2010 You do NOT want to block it off. if anything put a mini air filter on it. Quote Link to comment
sick620 Posted January 21, 2010 Author Report Share Posted January 21, 2010 cool thanks Quote Link to comment
sick620 Posted January 21, 2010 Author Report Share Posted January 21, 2010 what is this for.... it came with my air filter ......how do i mount this? Quote Link to comment
bonvo Posted January 21, 2010 Report Share Posted January 21, 2010 second pic is correct it connects to the nipple on the valve cover as for the vacume line the one further forward goes to the vacume advance i blocked the other one off with a vacume cap (follow the braided hose) Quote Link to comment
sick620 Posted January 21, 2010 Author Report Share Posted January 21, 2010 ok thanks thats what I thought. Quote Link to comment
TrevDaddy Posted January 21, 2010 Report Share Posted January 21, 2010 I am about to jump into this as soon as my weber shows up. So the valve cover hose connects to the white connection under the filter support plate? That would be the closest to the stock setup. Quote Link to comment
sick620 Posted January 21, 2010 Author Report Share Posted January 21, 2010 i only have one vacuum line on my carb bonvo. its going to my vacuum advance Quote Link to comment
sick620 Posted January 21, 2010 Author Report Share Posted January 21, 2010 bonvo did you have a egr or did you cover it up? Quote Link to comment
bonvo Posted January 21, 2010 Report Share Posted January 21, 2010 i only have one vacuum line on my carb bonvo. its going to my vacuum advance then you have a different model :P but thats fine you have it right bonvo did you have a egr or did you cover it up? no i dont i have an early l16 intake manifold that has been ported to match the l20b u67 head ports Quote Link to comment
