tnorth27 Posted January 11, 2010 Report Share Posted January 11, 2010 I really need help finding parts for my 1978 datsun b210 pls help, i need a new heaters system that is everything and possibly a new wiring harness Link to comment
Pumpkn210 Posted January 11, 2010 Report Share Posted January 11, 2010 Goin to the yard on tues or weds. Will keep the look out! Link to comment
speedman Posted January 16, 2010 Report Share Posted January 16, 2010 Im going tomarrow ill let u know Link to comment
datzenmike Posted January 16, 2010 Report Share Posted January 16, 2010 I really need help finding parts for my 1978 datsun b210 pls help, i need a new heaters system that is everything and possibly a new wiring harness Can I assume you have looked at wrecking yards in Texas and surrounding? A B210 heater found in Idaho isn't going to be cheap to ship there, plus the cost of buying it. Link to comment
tnorth27 Posted January 16, 2010 Author Report Share Posted January 16, 2010 price it out and i will let you know i have looked around hyere and as far as the army will let me travel Link to comment
CorAce Posted January 16, 2010 Report Share Posted January 16, 2010 I think it’s funny that you’re in Texas and looking for a heater. :rofl: Link to comment
tnorth27 Posted January 18, 2010 Author Report Share Posted January 18, 2010 im looking for the inner and outer tierods on both sides and an idler if u can find one Link to comment
ggzilla Posted January 18, 2010 Report Share Posted January 18, 2010 Idler just takes two new bushings, $10 at Nissan dealer or RockAuto.com Side rods (tie rods) are at RockAuto.com too. Link to comment
tnorth27 Posted January 30, 2010 Author Report Share Posted January 30, 2010 i need to find my speedometer cable when my speedometer says 60 im really going 70 Link to comment
datzenmike Posted January 30, 2010 Report Share Posted January 30, 2010 Cable won't change this. If it's bouncing then yeah but more likely you have larger than stock tires. The speedo cable is turned by a small gear drive in the tail stock. This gear is matched to the rear differential so if the tranny was changed and the gear not kept and installed in the new one, it could be for a different ratio. Likewise the rear diff could have been changed to a different ratio and this would upset the speedo gear ratio as well. Link to comment
tnorth27 Posted January 30, 2010 Author Report Share Posted January 30, 2010 the speed problem is more of a recent thing, i was on the highway and seeing what i could get it to go to well the speedometer said 80 and i heard a big bang and i think that started it, then a week and a half ago i got pulled over for 49 in a 40 and i know my speedometer said 40 and this happened after the bang Link to comment
ggzilla Posted January 31, 2010 Report Share Posted January 31, 2010 The speedometer is gear driven. A bang cannot alter the gear ratio. In the dash unit though the speedometer has a magnetic coupling. If the dash was hit real hard (think sledgehammer) maybe it could change the coupling... seems unlikely. Here's what you need, genuine Nissan speedometer gear, different colors are available for different gear adjustment Beware they are about $15 Link to comment
