kmc63 Posted January 8, 2010 Report Share Posted January 8, 2010 Provding nothing under the front end is bent(which its not) What all components should be replaced if I want my 510 to handle well. I have new bushings and lower ball joints. Quote Link to comment
banzai510(hainz) Posted January 8, 2010 Report Share Posted January 8, 2010 Frank and jeff replaced all mine and alighned it also Moog parts Quote Link to comment
xAH510x Posted January 9, 2010 Report Share Posted January 9, 2010 Frank and jeff replaced all mine and alighned it also Moog parts http://www.energysuspensionparts.com/proddetail.asp?prod=Moog%5FPackageDeal005 the moog steering kit comes with everything pretty much. Quote Link to comment
kmc63 Posted January 9, 2010 Author Report Share Posted January 9, 2010 I re-did the tie rods came new w/car along with all the bushings I need all rubber (no poly urethane). Although I would have went with those. Im going with what I have.So tie-rods done,have bushings,have lower ball joints,steering knuckle,what else? Quote Link to comment
paradoxx Posted January 9, 2010 Report Share Posted January 9, 2010 centerlink bar, idler arm? Quote Link to comment
kmc63 Posted January 9, 2010 Author Report Share Posted January 9, 2010 centerlink bar, idler arm? [/quoteDo those two components have bushings? If they are solid metal pieces without bushings,I probably wont replace them but if they have rubber in them you bet I will. All I know is the shocks are all new and upgraded 5 way adjustables,but the old components for the front end are most likely almost 40 years old. Time for some tlc. Quote Link to comment
benzo Posted January 9, 2010 Report Share Posted January 9, 2010 For me I replaced the tie rods,ball joints,shock and springs when did the zx conversion, T/C bushings with experimental engineering kit, adjusted steering box and added a brace,idler bushings with experimental engineering delrin kit, got alignment. car is steady. Quote Link to comment
kmc63 Posted January 9, 2010 Author Report Share Posted January 9, 2010 Thanks Benzo good info. My car is awfully twichy on a less than perfect road, I dont know if its because of worn front end components or because I have bigger wheels and tires. The front end needs re-built anyway hopefully this will fix it. Quote Link to comment
banzai510(hainz) Posted January 9, 2010 Report Share Posted January 9, 2010 New TC bushings will help. or those hard ones. I have the T3 adjustable TC rods now with No bushings and is just solid straight when I stop!!!!!!!!! Quote Link to comment
kmc63 Posted January 9, 2010 Author Report Share Posted January 9, 2010 New TC bushings will help. or those hard ones. I have the T3 adjustable TC rods now with No bushings and is just solid straight when I stop!!!!!!!!! Good to know banzai,I think I will feel much better about driving it when I get the front-end done. Its not a daily driver its my weekend toy,still a lot of little things to be done but I love my little 510. Quote Link to comment
