77 rustrat Posted November 28, 2009 Report Share Posted November 28, 2009 wassup everyone i am new to the forum and i just want to say that i love this forum is most definatly chock full of info and pics but i do have a problem. now i am not to computer savy and have trouble finding what i need. now i have a 77 620 that i am building into a bagged mini. my question is performance. i would like to know what i can do to the motor and what parts are available for this motor(L20B). any help would be much appretiated. ie. headers, cam, carbs, 5-speed upgrade(currently has 4-speed and at 85 it is dying for another gear and power lol), pretty much would like some tricks of the trade like what parts interchange and such that might yeild more other than bore and shave the head and such. so please give any advice you might have thanks in advance. Quote Link to comment
Z-train Posted November 28, 2009 Report Share Posted November 28, 2009 http://olddatsuns.com/ Quote Link to comment
77 rustrat Posted November 29, 2009 Author Report Share Posted November 29, 2009 okay that was a big help now what about a header any info Quote Link to comment
DISLEXICDIME Posted November 29, 2009 Report Share Posted November 29, 2009 stock l16 no smog ports off of a 73 620 get the y pipe also or go to ebay for a header Quote Link to comment
slam_dat_sun Posted November 29, 2009 Report Share Posted November 29, 2009 PICS OR FAIL :lol: :fu: :lol: Quote Link to comment
DatDoug Posted November 29, 2009 Report Share Posted November 29, 2009 Welcome to the forum. Would love to see pics of your truck. As for what you can do for more power there are a ton of posts on here of people building L20 motors, LZ22 strokers, swapping KA's. All kinds of info for you to find when you use the "Search" feature up above in the blu strip:D Just start reading and when you find out which way you want to go there will be plenty of help on here for you. Good luck & oh yah....PICS!!:fu: Quote Link to comment
Z-train Posted November 29, 2009 Report Share Posted November 29, 2009 Header?Not unless you plan on turning a bunch of RPMs on a regular basis.Stock manifold is superior for your average to above average truck motor. Quote Link to comment
datzenmike Posted November 29, 2009 Report Share Posted November 29, 2009 Find a good running '81-'82 Z22 from a 720 (or rebuild it) and fit your L20B oil pan, and all the timing gear and cover forward of the block onto it and top off with the L20B head. Use the L20B motor mounts to set it in your '77. You have now built an L22B stroker motor also known as an LZ22 or 'Frankenmotor'. Get a Weber 32/36 carb and L20B intake from a '78 or '79 and the L16 exhaust manifold, they are easily as good as a header. Increasing the engine size by 20% instantly increases the output by about 20% also so maybe 15 RWHP using stock Nissan used parts. If you spring for bigger cam the larger engine will make a larger power increase too over the same L20B. Further gains can be had by un-shrouding the valves and doing some porting and port matching to intake and exhaust. Maybe some larger 280zx valves. Quote Link to comment
77 rustrat Posted November 29, 2009 Author Report Share Posted November 29, 2009 yeah pics are coming in tomarrow i just started the forum today so tomarrow i will put some pics up. its all stock right now. but big things comming Quote Link to comment
