ummm......question
  • Replies 10
ok, we need clarification here. are you talking body panels? or are you talking brake components?
body panels.... yes. direct bolt over no issues.
brakes... no. they can be made to work with either adapter brackets to mount calipers onto the King Pins, OR cutom upper control arms with stock later lowers and steering knuckles.
i asked this same question when i first got my 73 620. from what i understand the mounts for the upper arms are set back a few inches on the later models than the earlier non disc setups. someone else on here SHOULD be able to tell you exactly what the difference is as i am not exactly sure.
