jarclay Posted October 14, 2009 Report Share Posted October 14, 2009 My Datsun friends, I got a good deal on an offy intake and holley 4 bbl. 390 cfm. carb setup for an L4 series. I plan to put it on an l20b block, A87 quench head and slight cam. Does any one have any experience with this setup? I have been told they were a bad combo, then told they worked great on a drag car. Your opinions??? As always thanks for your help and advice, James B. Quote Link to comment
ezcruiser Posted October 14, 2009 Report Share Posted October 14, 2009 I can't give you concrete results but I can tell you what I've found. A Weber 32/36 flows about 325CFM and Datsun enthusiasts have great luck with them! A Weber 38 (down draft) flows about 390CFM and I haven't really heard much on them helping out smaller engines. I had a weber 38 on a 4.2 liter toyota engine and it was close to perfect for me. You may be messing with the law diminishing returns.. Never done it though?~ I could definitely see it working out on a stroker, or something with a lot of head work?! Quote Link to comment
MAG58 Posted October 14, 2009 Report Share Posted October 14, 2009 The 390cfm works great on a mildly worked over L28 on a z car so I feel you'd be at a loss compared to a weber. I think you'd lose some drivability but increase top end. So yeah, it would make a good drag setup. Quote Link to comment
benzo Posted October 14, 2009 Report Share Posted October 14, 2009 If I remember a friend of mine several years ago used a holley on a lz2.2 he built and liked it but that was while ago and I did not see him drive the car much. I bet it may be too much for a L20 but if you have more displacement I bet it would work out. I personally say go with the weber but if this deal is smokin get it just to have for any future builds Quote Link to comment
Jesse C. Posted October 14, 2009 Report Share Posted October 14, 2009 I once used a dual plane Offy intake with a 32/36 weber and it sucked big time! Great setup for a truck, lousy on a 510! Quote Link to comment
zenndog Posted October 14, 2009 Report Share Posted October 14, 2009 I have a Holly 390 cfm carb on my chevy 283 v8, i also used it on a AMC hornet. It seems to me it would be way too much for a L4 unless as noted above you were really sucking a lot of air at high rpms. Quote Link to comment
