My 620 parts hunt begins!
I'm posting a list of all the parts I will eventually need to fix up my 1973 620 pickup. I will update the list as I get stuff. Let me know if you have anything on the list. I'm in Northern CA zip 95960.
hood (pending) - A few dings is ok but it has to be straight- I'm more concerned about bends, kinks, creases or cracks in the metal, rust holes or broken welds in the structural part.
tailgate - looking for a clean one (pending)
good set of heater controls with cables
intake coolant outlet fitting (can I get this at autozone?)
ignition switch (or better yet an entire lock set with matching key)
clips, screws and hardware for the ignition switch housing
head light switch knob or the entire switch
battery hold down
intact front turn signal lenses
12v flashers for the blinkers and hazard lights
a glove box door with an intact hinge or just the hinge part
an ash tray with track & all mounting hardware
stock tire jack (pending)
stock side view and rear view mirrors
an intact windshield
intact inner and outer window sweeps
door switches for interior lights
stock center console (does the bench seat have to be the notched type to install a center console?)
lock stems and trim
intact head liner (preferably white)
an intact dash pad (I might get a cap)
  • Replies 13
get the dash cap, good luck on the headliner and lenses for the front lower valance, it would be cheaper to get your liner done at an uhposltery shop, keep an eye out in the parts for sale section, check it several times daily for your best chance at what you need, exploit craigslist
good set of heater controls with cablesi have these $10
ignition switch (or better yet an entire lock set with matching key)i may have this, won't know till the weekend $75
head light switch knob or the entire switchhave this, $5
battery hold down
intact front turn signal lenseshave both sides $15 pr
lock stems and trim
may have one
1)tailgate - looking for a clean one (pending)
2)good set of heater controls with cables
3)intake coolant outlet fitting (can I get this at autozone?)
4)head light switch knob or the entire switch
5)battery hold down
6)intact front turn signal lenses
7)a glove box door with an intact hinge or just the hinge part
8)an ash tray with track & all mounting hardware
9)stock side view and rear view mirrors
10)an intact windshield
lock stems and trim
11)intact head liner (preferably white)
12)an intact dash pad (I might get a cap)
1)I have one
2)ditto
3)Which one?
4)Have one
5)Parts store-aftermarket
6)Dealer
7)Your dreamin'
8)Have it
9)Aftermarket
10)New from a glass shop(about 250.00 with a gasket)
11)Upholstry shop
12)Cap or bend over for "Just Dashes"
1)I have one
2)ditto
3)Which one?
4)Have one
6)Dealer
7)Your dreamin'
8)Have it
9)Aftermarket
11)Upholstry shop
Hey z-train, I sent you a private message. I'm in Northern Cali- are you willing to ship? Drop me an email and let me know: Paul(at)shiftpages(dot)com
7)Your dreamin'
I laid my eyes upon an unmolested one this evening! They are out there, just far and few between! If a certain some body lays his eyes on this thread, maybe he'll send you a reply :D
7)Your dreamin'
:lol:
  • 3 weeks later...
