SHIFT Posted October 4, 2009 Report Share Posted October 4, 2009 I have an L16 block with a W53 head in a 73 620. I want to get a Weber conversion kit- which one do I get? Best place to order?:mellow: Quote Link to comment
datzenmike Posted October 4, 2009 Report Share Posted October 4, 2009 http://www.redlineweber.com/html/kits/k660.htm Quote Link to comment
VoidDragon Posted October 4, 2009 Report Share Posted October 4, 2009 As a follow up for all us newbies on here, what do you do with all the smog stuff on the intake when you switch over to a weber? It seems you cant run the stock intake on one, correct? Quote Link to comment
datzenmike Posted October 4, 2009 Report Share Posted October 4, 2009 The only smog thing on the intake is if it is equipped with EGR. Find the vacuum line that goes to the valve and remove and plug. It needs ported carb vacuum to work... no vacuum signal... no work. Install the Weber and go. All intakes have a PCV valve but I don't consider it a 'smog device'. (even though it sort of is) It is essential for keeping the engine insides free of condensed gas and water vapors that will dilute the oil and that's just not good. Does not affect running or performance in any way even if the hoses fall off or get plugged. Best to run with it working properly. Quote Link to comment
SHIFT Posted October 5, 2009 Author Report Share Posted October 5, 2009 http://www.redlineweber.com/html/kits/k660.htm Awesome! thanks. Quote Link to comment
84nissan720 Posted October 5, 2009 Report Share Posted October 5, 2009 how much those a Weber conversion kit cost??????? Quote Link to comment
nismo dr Posted October 5, 2009 Report Share Posted October 5, 2009 how much those a Weber conversion kit cost??????? around $300 +/- Quote Link to comment
datzenmike Posted October 5, 2009 Report Share Posted October 5, 2009 Seems like a lot but you get everything here: Quote Link to comment
Charlie69 Posted October 5, 2009 Report Share Posted October 5, 2009 If you want the IC solenoid you want the K663 kit. http://www.webercarbsdirect.com/product_p/wk663.htm $319.95 shipped free If you are buying I'll take one too.:lol: Quote Link to comment
SHIFT Posted October 5, 2009 Author Report Share Posted October 5, 2009 If you want the IC solenoid you want the K663 kit. http://www.webercarbsdirect.com/product_p/wk663.htm $319.95 shipped free If you are buying I'll take one too.:lol: What is an IC solenoid? How do I know if I have one or need one? Quote Link to comment
Guest DatsuNoob Posted October 5, 2009 Report Share Posted October 5, 2009 (edited) As a follow up for all us newbies on here, what do you do with all the smog stuff on the intake when you switch over to a weber? It seems you cant run the stock intake on one, correct? L16 intake manifold. Early, pre-smog exhaust mani (without flapper unit for anti carb icing) or header. Sure beats making all the block off plates. That is if you live in an area that doesnt require emission control. Pretty much any Weber kit will work, provided you have the correct adapter plate/s. Weber makes different variations of the same basic carb, 32/36 being the most common, I had the 34/34 which was a little different as far as the linkage setup, but you can make anything work with a little Ratsun ingenuity Edited October 5, 2009 by DatsuNoob Quote Link to comment
banzai510(hainz) Posted October 5, 2009 Report Share Posted October 5, 2009 u have a w53 head which is less prone to detonation. I would get the cheap man choke type DGV 5A myself. or if you have a electric choke get the 32/36DGEV. webercarbsdirect has these and others. Quote Link to comment
Charlie69 Posted October 5, 2009 Report Share Posted October 5, 2009 IC (Idle Control) circuit shuts off the flow of gas when you turn off your motor. I suggest this carb because if you ever swap in an L20B motor you will need this as they are prone to dieseling (running on) after ignition is shut off. The factory carbs for the L20B's have this solenoid circuit on them. On your L16 you propably won't need it so you don't hook up the wire, but if you do need it you just hook up a wire. It is simple. Here is the cheapest I have found this carb $40 cheaper: http://cgi.ebay.com/ebaymotors/Nissan-Datsun-1968-1982-Weber-Carb-Conversion-Kit_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem1e58543696QQitemZ130330932886QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment
SHIFT Posted October 5, 2009 Author Report Share Posted October 5, 2009 IC (Idle Control) circuit shuts off the flow of gas when you turn off your motor. I suggest this carb because if you ever swap in an L20B motor you will need this as they are prone to dieseling (running on) after ignition is shut off. The factory carbs for the L20B's have this solenoid circuit on them. On your L16 you propably won't need it so you don't hook up the wire, but if you do need it you just hook up a wire. It is simple. Here is the cheapest I have found this carb $40 cheaper: http://cgi.ebay.com/ebaymotors/Nissan-Datsun-1968-1982-Weber-Carb-Conversion-Kit_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem1e58543696QQitemZ130330932886QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Thanks for the info on the IC circuit and thanks for the link! Quote Link to comment
SHIFT Posted October 5, 2009 Author Report Share Posted October 5, 2009 Done. I just ordered the Weber kit. :D Quote Link to comment
Charlie69 Posted October 5, 2009 Report Share Posted October 5, 2009 Did you order mine too?:eek: Quote Link to comment
SHIFT Posted October 5, 2009 Author Report Share Posted October 5, 2009 Did you order mine too?:eek: I ordered the k663 kit as you suggested, but just one- for my truck ;) Quote Link to comment
