Charlie69 Posted September 18, 2009 Report Share Posted September 18, 2009 (edited) Does anyone know the torque specs for flex plate to crank bolts, and flex plate to torque convertor bolts for a 1976 620 L20B with the 3N71B automatic? Edited September 18, 2009 by Charlie69 typo Quote Link to comment
mazdat Posted September 18, 2009 Report Share Posted September 18, 2009 (edited) here's a 620 torque specs page http://www.olddatsuns.com/620tech4.htm#TS2 Edited September 18, 2009 by mazdat Quote Link to comment
Charlie69 Posted September 18, 2009 Author Report Share Posted September 18, 2009 (edited) Thank you for the link, but there is no torque specs given for automatics. Still looking for the torque specs for flex plate to crank bolts, and flex plate to torque convertor bolts for a 1976 620 L20B with the 3N71B automatic. Thank you, Charlie Edited September 18, 2009 by Charlie69 typo Quote Link to comment
1Low620 Posted September 18, 2009 Report Share Posted September 18, 2009 Tried locating this information for you in my book.....it don't give specific models, just says 12-15ft lbs on 1970-1979 models and 16-22ft lbs on 1980-1988 models. Quote Link to comment
datzenmike Posted September 19, 2009 Report Share Posted September 19, 2009 Do NOT forget the two spacers in front and behind the drive plate when mounting to the crank shaft!!!! Drive plate (or flex plate) to crank bolt torque................. 101-116 ft. lbs. Drive plate to torque converter........................................ 29-36 ft. lbs. This is the FSM specs for a '78 620 L20B with 3N71B automatic. Gotta be the same. Quote Link to comment
Charlie69 Posted September 19, 2009 Author Report Share Posted September 19, 2009 (edited) Thank you Mike I appreciate it. I have been trying to locate those specs for a while now. Where did you find the information if you do not mind me asking? Ihave a 76 620 FSM and a 1980 720 FSM and was not able to locate those specs in either manual. Charlie Edited September 19, 2009 by Charlie69 Added Quote Link to comment
datzenmike Posted September 19, 2009 Report Share Posted September 19, 2009 This is the FSM specs for a '78 620 L20B with 3N71B automatic. Gotta be the same. Factory Service Manual for the '78 truck. I also have an '84 720 handy as well... same torque specs. It's at the back of the automatic transmission section just before the Special Service Tools Quote Link to comment
Charlie69 Posted September 19, 2009 Author Report Share Posted September 19, 2009 You are the Datsun man!:cool: Same as my 1976 620 FSM & MY 1980 720 FSM. Thank you again, Charlie Quote Link to comment
1Low620 Posted September 19, 2009 Report Share Posted September 19, 2009 Factory Service Manual for the '78 truck. I also have an '84 720 handy as well... same torque specs. It's at the back of the automatic transmission section just before the Special Service Tools And my book says it covers every thing from 1970-1988! Not sure what torqs I listed, maybe the tranny pan? :confused: Quote Link to comment
1Low620 Posted September 19, 2009 Report Share Posted September 19, 2009 Never mind, after re-reading it a few times those are torq specs for the clutch cover -to- the flywheel! Quote Link to comment
