Titanic
Loz
Yup, she sprung a leak!
stopped at the services after cruising at about 50mph for 20kms. Water dripping from (seemingly) behind the pulley (water pump??)
Not sure if its old cracked bottom hose or it is actually from behind the pull and not just running down and dripping there.
Bugger...
Something new every time out.. but that what you get with old cars...
She got me home fine (37 bht for 6l of drinking water from 7/11) Only took a 2 litre top up.
Next:
Oil leak from around the (now unused) fuel pump. drips reach the manifold and get smelly.
ANy know faults around this area that cause such a leak?
:mellow:
  • Replies 6
Mechanical fuel pump seems to always leak.
I've swapped on a couple new pairs of gaskets, tried light and heavy amounts of gasket dressing, and even double-checked the torque specs on those bolts. They just don't hold a seal too well. It should have 3 or 4 bolts i think instead of just two.
If you're running an electric fuel pump then a block-off plate for the mechanical one might fix your problem.
Thanks,
does that mean making a block off plate or is such a thing available?
I've got fuel hose linking the out put and input nozzles on the pump. don't think the oils coming out through them, do you?
IIRC a SBC block off is very close...
or make your own! just dont use a full tube of RTV :rollseyes:
often the diaphragm on the stock pump is what leaks...gas and/or oil :cursing:
http://i138.photobucket.com/albums/q251/datzenmike/L%20Z%20Heads%20and%20Motors/motorfuelpumpblockoffZ20Z22.jpg[/img]"]motorfuelpumpblockoffZ20Z22.jpg
Use this for a block off plate.
http://i138.photobucket.com/albums/q251/datzenmike/L%20Z%20Heads%20and%20Motors/00770026.jpg[/img]"]00770026.jpg
It's from any Z20 or Z22 head (bottom one) and NOT the Z24. (top)
Had an L fuel pump that someone put a tiny dab of RTV on each side of the pivot pin. Seemed to work.
Edited by datzenmike
