yello620 Posted August 13, 2009 Report Share Posted August 13, 2009 :fu::fu:your making me feel old.:lol::fu: Quote Link to comment
yello620 Posted August 13, 2009 Report Share Posted August 13, 2009 Tim, I looked up the wiring diagram for your 85 and it shows a white wire on the battery charge stud and a white wire at the sense terminal, and a blue/white wire at the lamp terminal. Good luck Quote Link to comment
izzo Posted August 13, 2009 Author Report Share Posted August 13, 2009 Thanks jason today i knew of a dead 720 4x4 so i went and checked it out, bought the alternator off it for 20 dollars. i swiped the electrical connector off the harness too. The stock 720 4x4 alternator connector is a PERFECT fit on the KA alternator. Snug when snapped in, slides in easy. so that just leaves the earth wire and battery wire which will be easy. I measured the the stock 720 alt and the base width is 3 1/8th. I measure the KA and its a little bit wider, but its 3 1/8 with that metal bushing in there. so itll work out perfectly! Quote Link to comment
izzo Posted August 13, 2009 Author Report Share Posted August 13, 2009 heres the stock 720 connector, and then the alt. wiring even matches up to what you said :D Quote Link to comment
nis720 Posted August 13, 2009 Report Share Posted August 13, 2009 I have a few plugs that will fit as well. These are misc plugs off a 240sx harness. Quote Link to comment
yello620 Posted August 14, 2009 Report Share Posted August 14, 2009 Thanks jason I measured the the stock 720 alt and the base width is 3 1/8th. I measure the KA and its a little bit wider, but its 3 1/8 with that metal bushing in there. so itll work out perfectly! Tim, that steel sleeve is designed to slide inside the aluminum housing.:D It allows you to open that space for an easier install.:D Just tap it with a hammer, and when you tighten your bolts it will slide back to snug on the bracket. Quote Link to comment
izzo Posted August 25, 2009 Author Report Share Posted August 25, 2009 Tim, that steel sleeve is designed to slide inside the aluminum housing.:D It allows you to open that space for an easier install.:D Just tap it with a hammer, and when you tighten your bolts it will slide back to snug on the bracket. I still have the KA alt in the back of my truck. i put a stock one in the 4x4. i need to get the right pulley :D Quote Link to comment
