bigjoe619 Posted July 30, 2009 Report Share Posted July 30, 2009 hey fellas i just came across a electronic distributor and its not the match box one its the one with the lil black box on the inner fender well, the one with the green and red wire commin off it... so what do i need to do to mae it work on my 510? does anyone have a matchbox one they wanna sale Quote Link to comment
datzenmike Posted July 30, 2009 Report Share Posted July 30, 2009 If it's black and about 2" square you may be referring the terminal box. If it is a remote igniter dizzy you can get it working with a GM HEI unit for about $15-$20. You will need an EI coil to go with it. The points coil will overheat. http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/wiringHEI4.jpg[/img]"] Under the cap, does it look like this one?... http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/EIdizzyremoteigniter.jpg[/img]"] ...or this one? http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/EIdizzymatchbox.jpg[/img]"] Quote Link to comment
bigjoe619 Posted July 30, 2009 Author Report Share Posted July 30, 2009 it looked like the first one so would you happen to know a part number the gm hei and what kind of coil Quote Link to comment
yello620 Posted July 31, 2009 Report Share Posted July 31, 2009 I have been told that you can also use a late model Nissan igniter box with your early distributor. But i have never tried that. And i have a Matchbox style that i would like to sell too. With coil and pedestal. Quote Link to comment
Pacific coast Datsun Posted July 31, 2009 Report Share Posted July 31, 2009 it looked like the first one so would you happen to know a part number the gm hei and what kind of coil Go to Kragen,tell them you need a HEI module for a 77 Chevy Camaro. Cost bout $15. Coil, youll need an electronic one off a Datsun that came stock with electronic ignition. It will be wider & a bit taller than a points coil. Quote Link to comment
datzenmike Posted July 31, 2009 Report Share Posted July 31, 2009 Almost any Nissan coil from '78 on will be EI compatible. Quote Link to comment
