Guest DatsuNoob Posted July 28, 2009 Report Share Posted July 28, 2009 I've got a KA24de from a 98 Frontier 4X4. Has the central sump pan which may fit between a flipped X-member and steering link on a 510. This motor would be the ideal candidate for a 620 if you change the pickup tube and do a rear sump pan swap from the 2wd frontier. Unknown mileage/condition, but it looks clean, no water in the oil, and turns freely. I would build this motor if I didnt have so much other work to do. I will include the whole truck intake manifold w injectors and fuel rail also, as well as a 240sx crank pulley. You will need to locate a front timing cover for it since there are 2 small cracks on the rim of the crank seal area. JBweld? I dunno. First $100 takes it. Link to comment
Guest DatsuNoob Posted July 28, 2009 Report Share Posted July 28, 2009 (edited) Thanks, I'm open to reasonable offers also. This would be a great place to start on a KA build. I may also be open to trades as well. Things I'm looking for: pair of clean seats, a nice hood, a straight passenger door and/or tailgate, a KA intake, nice headlights, maybe something else you have? Shoot me an offer Edited July 28, 2009 by DatsuNoob Link to comment
Guest DatsuNoob Posted July 29, 2009 Report Share Posted July 29, 2009 Just a little FYI, took off the valve cover and checked out the cams. Alot better than the ones in the motor I'm using. No bronzing or discoloration! Has good compression when I turned the crank. I wouldnt be surprised if this turns out to be a running motor. Timing chain is tight and in good shape too. If nobody picks this up, I may seriously consider keeping it around as a builder. Thanks Link to comment
rzrdisco Posted July 29, 2009 Report Share Posted July 29, 2009 hm.. kind of tempting. too bad you don't want 510 stuff. but it's not like i need more engines sitting in my garage either :blink: Link to comment
Guest DatsuNoob Posted July 29, 2009 Report Share Posted July 29, 2009 I'll take a 510 :D. Link to comment
Icehouse Posted July 29, 2009 Report Share Posted July 29, 2009 HHHMMMM very tempting :D Link to comment
Cuts metal like mad Posted July 29, 2009 Report Share Posted July 29, 2009 Only tempting for a single Benjamin? Good lord... bring a bell housing by and we can do a compression test! Then the price goes up! :D Link to comment
philcas1987 Posted July 29, 2009 Report Share Posted July 29, 2009 I offer h4 hid 8000k kit with halogen high beams. Link to comment
