need oil spray bar install info
  • Replies 8
Guest DatsuNoob
I think there was a picture and maybe even a couple paragraphs on it in the Honowentz book, HOW TO MODIFY YOUR L SERIES? Didn't look too hard to do. You have to drill into your valve cover, and run a line off your oil pump I think, but not 100%, I hear it's beneficial to upgrade to the KA oil pump for that kind of set-up, this may help a little http://datsun510.wikia.com/wiki/Nissan_L_engine_cylinder_heads good luck on the search
Edited by DatsuNoob
I have seen them installed and they dont look to hard to do just some good measuring before the drilling, run a tee off of the oil pressure tap on the side of the block to the fitting on the valve cover... With that said totally not needed if your running a cam under a 1/2" lift with stock valve springs
clayton
You know your not going to run a half inch cam with STOCK valve springs!
just get a 280zx turbo oil pump or a KA pump
:lol::lol::lol: I know, but some have tried
Clayton
i dont have a way to upload the directions... try contacting wolf creek racing and see if they have them, they sell them.
i can post the dimensions and pix of my install...
3(2-s / 1L) holes in the VC, & a wee bit of grinding on the support ribs.
