Mini-L320 Posted July 14, 2009 Author Report Share Posted July 14, 2009 I sent a PM to bagged320, hopefully he can help me out. I have a picture in my mind on how Im gonna make it work, its hard to explain but when I get t right I will get pictures for everyone to see. Quote Link to comment
Mini-L320 Posted July 14, 2009 Author Report Share Posted July 14, 2009 Bagged320 doesnt have the same suspension as mine thats why he was probably able to make his header fit in perfectly with out it have problems. He doesnt have A-arms on his anymore, because of the Air bags. Quote Link to comment
zenndog Posted July 14, 2009 Report Share Posted July 14, 2009 You guys may be better off to put your engines in without the headers and build them around what you have. Personally, I have never been around a rotory engine to see how the exhaust mounts or even where it mounts. I guess I could go find some pictures and see what comes to mind. Unless there is a major major issue like the exhaust comes out right into a part of the frame suspension, put the motor where it needs to be and modify the headers after. From the pics, that header looks very simple, measure the length, cut off the flange, get some tubing and make a new one the shape you need. You have to get the engine and trans that you are going to use mounted first so you can route the header/exhaust around what is going to be in there when your done. The length and diameter of the tubing are the important thing and that header looks so simple, buy the pre-bent, cut and weld, You can make it just how you want/need it. Just keep the length of each pipe the same as before you cut it. Or how about some drag-style fender well headers. Just blast it out the well!!!!:eek: Quote Link to comment
zenndog Posted July 14, 2009 Report Share Posted July 14, 2009 (edited) Edited July 14, 2009 by zenndog Quote Link to comment
Jester Posted July 14, 2009 Report Share Posted July 14, 2009 Fender well headers would look bad ass if you were going with the gasser look. :D:D Quote Link to comment
Mini-L320 Posted July 14, 2009 Author Report Share Posted July 14, 2009 If i just blast the headers out the wheel well with nothing else that would be super duper LOUD!:), not saying that, that is a bad thing but I will get pulled over by every cop that sees me. especially having that on a rotary engine, way to loud. Im just gonna mount everything on the truck and see where that takes me before I costumize the header. Quote Link to comment
Jester Posted July 15, 2009 Report Share Posted July 15, 2009 If i just blast the headers out the wheel well with nothing else that would be super duper LOUD!:) :lol::lol: No No No, You run the REST of your exhaust under the truck. The fenderwells are just for looks. Quote Link to comment
Jester Posted July 15, 2009 Report Share Posted July 15, 2009 check out this Stout Gasser . :D Quote Link to comment
Mini-L320 Posted July 15, 2009 Author Report Share Posted July 15, 2009 That is a Badass Drag racing Yota, ok so I have so more pictures of the engine on the truck as of today. Quote Link to comment
Mini-L320 Posted July 15, 2009 Author Report Share Posted July 15, 2009 here it is again but with the radiator. Im gonna go with dual electric fans for the radiator instead of using the fan of the engine. Quote Link to comment
Mini-L320 Posted July 15, 2009 Author Report Share Posted July 15, 2009 That 4 barrel is looking pretty good just about know, :D:D:D Quote Link to comment
Mini-L320 Posted July 15, 2009 Author Report Share Posted July 15, 2009 here is what we are looking at from the inside of the cab, I will need to cut of some of the firewall so that the bellhousing can fit in. after its all put on I will make another custom firewall to cover up the evidence ::rolleyes::D and I also took of the heater as you can see, and I will mount it somewhere else. Quote Link to comment
bagged320 Posted July 19, 2009 Report Share Posted July 19, 2009 i have racing beat headers on mine, my engine is a 13b which is alittle diff, i didnt have any clearence issues with my headers, i did remove my a-arm and shock mount when i bagged it and made a smaller ones but they didnt hit before that either, not sure how good your fab skills are but you could do that and make new arm mounts, if i where you i would just make some new headers to fit, or check out the racing beat website and see if they can send you dimensions of there headers, sorry it took so long to respond Quote Link to comment
bagged320 Posted July 19, 2009 Report Share Posted July 19, 2009 oh and if you cant find bent exhaust tube to make headers with i usually check my local motorcycle fab shop, they always have a bunch of diff bent tubes in all diff sizes for making custom exhaust you can pick up for cheap or if there cool might just give you Quote Link to comment
Mini-L320 Posted July 20, 2009 Author Report Share Posted July 20, 2009 yeah thats what Im going with, I already cut the headers that I have and making custom bent ones myself. I have everything all set now, thanks Quote Link to comment
Mini-L320 Posted July 23, 2009 Author Report Share Posted July 23, 2009 I havent worked on the truck lately since it has been raining, but I picked up some nascar looking rims for it. 8 inch wide up front and 10inch wide on back. the tires are really streched out on back. its a 215/50/15 on a 10inch wide rim. looks very nice. I will get some pictures. Quote Link to comment
Mini-L320 Posted July 24, 2009 Author Report Share Posted July 24, 2009 Rotary Decals :fu: Quote Link to comment
