a.d._510_n_ok Posted June 29, 2009 Report Share Posted June 29, 2009 Ripped my 1980's front end apart today to put in new struts, tie rod ends and A-arm bushings. Everything came apart pretty easily. I grabbed the now unattached passenger side A-arm, wriggled it back and forth and heard a very metallic sounding "click-click" and thought, "Yeah, that bushing is pretty bad". When I took the bolt out of the center of the first A-arm bushing I noticed that the bolt had a groove worn in both ends from where it had been seated in the stamped "crossmember". Just for the hell of it, I found a bolt the same shaft size, jammed it through the crossmember and bushing and the "click-click" disappeared! The bushing looks mint - I may just leave it. Quote Link to comment
a.d._510_n_ok Posted September 5, 2009 Author Report Share Posted September 5, 2009 Also, on my '80 510 the original A arm bolts were 10mm shafts, grade 8.9 and were pretty loose in the A-arm bushings. I replaced them with 1996 Pontiac Grand Prix engine mounting bolts that were 3/8 shaft (took up the slack in the bushing but still moved very freely) that were grade 10.9. I have no clue what size they are on other Datsuns but if they are a 10mm upgrades are as close as the top engine brackets/mounts on a GM 3.1 V6. Quote Link to comment
1Low620 Posted September 14, 2009 Report Share Posted September 14, 2009 (edited) Also, on my '80 510 the original A arm bolts were 10mm shafts, grade 8.9 and were pretty loose in the A-arm bushings. I replaced them with 1996 Pontiac Grand Prix engine mounting bolts that were 3/8 shaft (took up the slack in the bushing but still moved very freely) that were grade 10.9. I have no clue what size they are on other Datsuns but if they are a 10mm upgrades are as close as the top engine brackets/mounts on a GM 3.1 V6. I'd be really careful what type of bolts you start throwing in holes, a 3/8 dia NC bolt is almost the same as a 10mm however the grading system is a LOT different. 3/8-16 NC you're either looking at grade2, grade2 zinc, grade 5, grade 5 zinc, grade 8, grade 8 zinc, grade 8 zinc yellow. 3 hash marks on the top of the sae bolts signify it's a GRADE 5 6 hash marks on top of the sae bolts signify that it is a GRADE 8 Metric bolts are stamped 8.8,8.9,10.9, 11's and some 12's that I've come across. I wouldn't be caught dead sticking anything less than a grade 8 in an a-arm or anything else that gets serious vibration.... it will bend and break over time. I sell nuts and bolts for a living :D, get these types of questions all day long. Edited September 15, 2009 by 1Low620 Quote Link to comment
MikeRL411 Posted September 15, 2009 Report Share Posted September 15, 2009 Just remember! SAE Grade 8 and the various Metris 8.whatever are NOT the same! Quote Link to comment
Skib Posted September 15, 2009 Report Share Posted September 15, 2009 Just remember! SAE Grade 8 and the various Metris 8.whatever are NOT the same! ya thats an important one to not over look, dont quote me on it but I think a metric 8 is = to an SAE 5? Quote Link to comment
1Low620 Posted September 15, 2009 Report Share Posted September 15, 2009 (edited) ya thats an important one to not over look, dont quote me on it but I think a metric 8 is = to an SAE 5? **ninja edit** let me rephrase that. You can look at several metric thread charts and they will state 8.8,.9,.10 are close to grade 8 sae, if you look at the charts they will show material and tensil strengths, if you use a hardened steel, it is close to an sae grd 8, mild steel and low alloys reduce it down to = some where close to sae grade 5 Edited September 15, 2009 by 1Low620 Quote Link to comment
a.d._510_n_ok Posted September 18, 2009 Author Report Share Posted September 18, 2009 so is this chart wrong :confused:? Approximately Equivalent Grades 10.9 SAE J429 = grade 8 http://www.sizes.com/tools/bolts_metric_standards.htm Quote Link to comment
1Low620 Posted September 18, 2009 Report Share Posted September 18, 2009 so is this chart wrong :confused:? Approximately Equivalent Grades 10.9 SAE J429 = grade 8 http://www.sizes.com/tools/bolts_metric_standards.htm It all depends on the material, metric bolts can be made from several materials that have different tensil strengths. Out of curiosity I looked in my system today and and I'll use an example of what I found on a M10 x 40mm Hex head bolt. I've got them listed as this. M10 x 40 Hex Head 10.9 Plain ( this is just a plain black oxide look ) M10 X 40 Hex Head 10.9 Zinc ( blueish coloring ) M10 X 40 Hex Head 10.9 Zinc Yellow ( same as the second, just a yellow color ) M10 X 40 Hex Head 10.9 A2 ( This is stainless, tensil strength is lower than any of the above ) M10 X 40 Hex Head A307/304 ( again, the material is stainless and tensil strength is lower ) As you can see, even with the stainless stamped with a 10.9, it's not equal to the plain, zinc or zinc yellow bolts. Hope I didn't confuse you, even with all this great information on the internet, stuff can be very misleading. In short, grab a 10.9 grade metric bolt that isn't of stainless material and you will be golden. Quote Link to comment
1Low620 Posted September 18, 2009 Report Share Posted September 18, 2009 Also, I see you're in Oklahoma, where about's are you? I know blackwell has a Fastenal company there, not sure about OK city,ponca,enid,stillwater ect. That company is like weeds, they're every where. Their prices should be a lot lower than a local true value or what ever they call them back there :) Quote Link to comment
a.d._510_n_ok Posted September 18, 2009 Author Report Share Posted September 18, 2009 1Low, I ain't sure what it was made of it but it was black (with a rough finish) and not stainless. Yeah, got a fastenal about 16 miles from me - those people think nothing of spending fifteen minutes helping you find one specific nut or bolt - nice folks! Quote Link to comment
