bucket Posted June 26, 2009 Report Share Posted June 26, 2009 volts were running bout near 16 .... funny sound from reg after a week or so. got new volt reg. now volts are right (13.9ish) odd sound now in new volt reg when rps down. sooooo.... alt brushes ? new altenator? or else? Quote Link to comment
ggzilla Posted June 26, 2009 Report Share Posted June 26, 2009 The new solid state regulators make no sound. The original Datsun type, being electro-mechanical relays might make a little buzzing or cliking sound, but I've never noticed. Is it a whining sound? If so that like to be a blown diode in the alternator. Quote Link to comment
bucket Posted June 26, 2009 Author Report Share Posted June 26, 2009 its exsactly tht sound comeing from the volt reg. guess ill pull it after work tomorrow and get the altnator checked out. Quote Link to comment
ggzilla Posted June 26, 2009 Report Share Posted June 26, 2009 (edited) Yes, there are three diodes in an alternator. If one blows/breaks, the alternator tends to whine. Had that happen several times in different makes of cars. They seemed to charge OK with one open diode, but I eventually replaced the alternators just in case... Sometimes you can takes them apart and test the diodes with an ohmmeter, but not with the Datsun Hitachi units. You'd have to unsolder these type to isolate the diodes for testing. I just swap Datsun alternator for another good used unit... Edited June 26, 2009 by ggzilla Quote Link to comment
banzai510(hainz) Posted June 26, 2009 Report Share Posted June 26, 2009 get a solid state Volt reg or IR alternator your alternator is fine I bet. Quote Link to comment
bucket Posted June 26, 2009 Author Report Share Posted June 26, 2009 i already got a new volt reg in there. and thats were the sound is comeing from just like the bad one started doing. it sounds like a skweeky floor board or old door hinge when the car starts mostly. just bought it threw schucks. so its gotta be something else makeing it do that. Quote Link to comment
banzai510(hainz) Posted June 26, 2009 Report Share Posted June 26, 2009 Alternator??????? Quote Link to comment
datzenmike Posted June 26, 2009 Report Share Posted June 26, 2009 For the price of a new regulator get a '78 and up alternator from the wreckers. The regulator is built in and is quiet. All regulators will make some sound because of the opening and closing of the contact points inside. Quote Link to comment
banzai510(hainz) Posted June 28, 2009 Report Share Posted June 28, 2009 Tim said He put another voltreg in and it making the same noise. I never had a new volt reg bad from the store. Tim(bucket) has ordered another. But Im wondering if the alternator has a bad diode or something passing 60 cyles waveform instead of the 120(bridge rectifier) and the mechanical volt reg cant keep up thus making the noise. Make friends with frank and jeff so you can some spare volt regs and alternators as they thru some of that stuff away last week. Quote Link to comment
bucket Posted June 28, 2009 Author Report Share Posted June 28, 2009 well schucks got me a fresh volt reg after they checked me alt and battery. ( wich were good) and what do you they did give a bad reg. but so far so good with the newest reg. Quote Link to comment
banzai510(hainz) Posted June 29, 2009 Report Share Posted June 29, 2009 I know you told them to get a solid state unit!!!!!!!!!!!! Quote Link to comment
alleycat Posted November 15, 2009 Report Share Posted November 15, 2009 so, after i put in a new voltage regulator, (because of the charging light flickering), i started hearing a whining, squealing also. now what? alternator? belts? easy fix. sorry about high jacking your thread. Quote Link to comment
banzai510(hainz) Posted November 16, 2009 Report Share Posted November 16, 2009 how about putting a volt meter on there first? it can still be ok charging wise but alternator have bearings and they can wear also. or the water pump bearing maybe can squeal but more likely wear out and get loose cause of too much tension on the bearing by tightening the belt too tight puts too much of a preload on there. could be a bad belt also. if you have ac that could be that belt also. Quote Link to comment
alleycat Posted November 16, 2009 Report Share Posted November 16, 2009 thank you. Quote Link to comment
