engines dont pop. or do they?
moparvwfreak
i was working on the Bucket today, and i had it running for a leak check of the cooling system. no leaks i could see but i need a new thermostat housing. the one on the block, not the cap. and i heard this,
http://smg.photobucket.com/albums/v422/moparPW200guy/78%20620/?action=view&current=061409004.flv
any ideas??? i didn't think engines were supposed to sound like thy are popping popcorn. i really dont want to have to scrap this motor as i want to put it into my 73 eventually.
  • Replies 5
hmmm..... if ya revv it up what does it do? I had a small nut fall in my alternator once and it sounded similar.... maybe remove the belts and run it briefly to see if it goes away.... underhood noises can be deceiving.
i'll check that. i know i have all 3 bolts for the alt on this one but one is loose. i even held the alt while it was running and the same sounds emitted. but i will look into that. thanks!
and yes. valve adjustment was done a month ago, adn while i was in there i checked the guides and nothing was out of the ordinary. this is one that just creeped up on me.
