PREACHPRO Posted June 7, 2009 Report Share Posted June 7, 2009 I have a 1974 620 pickup , i want to know will a 1.5 datsun engine fit in my truck?i know it is a smaller engine than the 1.8 but it is the only one i could find. It came out of a datsun car i think,what kind i don't know. Please let me know before i buy this engine Quote Link to comment
izzo Posted June 7, 2009 Report Share Posted June 7, 2009 (edited) the L series L16 (which is 1.6L) should be just fine it cant be the A series engines.... this is what the L series engines look like, all look identical, tho the l16 and l18 are a little shorter then the l20 so the chain is different etc... This is the A series engines, Dont pay any attention to the carb setup really, its not important for what your asking What you need to look ad is the engine, the valve cover is a major give away, also the A series engines have the distributor on the passenger side and the L series has it in front on the driver side. Edited June 7, 2009 by h2theizzo Quote Link to comment
Bleach Posted June 7, 2009 Report Share Posted June 7, 2009 I would say it will fit just fine. Its physically smaller. It wont' bolt in though because of the different engine mounts and need for a different transmission. Finding an L-series engine, even a 1.6L L16 would make the intall much easier. Quote Link to comment
datzenmike Posted June 7, 2009 Report Share Posted June 7, 2009 As Bleach says. So much needs to change you might as well swap a Honda/Toyota/Mazda... whatever in there. .... wait...no. Get a newer Nissan 4cyl and tranny. A 720 truck 4cyl. Z series motor will fit including the D-21 Hardbody to '90. Get one from a 2wd. I have a Z24 in my 620. Quote Link to comment
izzo Posted June 7, 2009 Report Share Posted June 7, 2009 sorry from my understanding he was just wanting to replace the engine with another stock one for his 620 listen to bleach and mike they have tons more info then i do :lol: Quote Link to comment
yellowdatsun Posted June 7, 2009 Report Share Posted June 7, 2009 Yeh but I'd be really surprised if he's asking about an L-15, probably an A series if he says it from a car. Just find another L-16-18-20 from someone, because as mentioned already you'll end up having to make all the mounts, engine and transmission, to throw in an A series. Way too much work only to end up with a *smaller* engine. Quote Link to comment
ggzilla Posted June 7, 2009 Report Share Posted June 7, 2009 Will a 1.5 a-series fit into a 620 truck?Yes a 1.5 A-series engine will fit with plenty of room. In fact I've heard of it being done before. But it is not bolt in. You'd have to faricate mounts, linkage, and driveshaft. A J15 Datun engine would fit using factory parts. That 620s in Japan use the J15 engine. Quote Link to comment
Bleach Posted June 7, 2009 Report Share Posted June 7, 2009 Let me give some info here. He posted this off-topic in another thread so I moved it. He only said it was a 1.5L, I made an assumption and put a-series to help out his title description. I could be wrong. I forgot about the J15 either way, I think my original answer still stands. Any 4-cyl L-series will be way easier if you're looking to just throw in a running engine. Quote Link to comment
PREACHPRO Posted June 9, 2009 Author Report Share Posted June 9, 2009 Thanks for all the imput.i just wanted to ask the question because no one knew around here.i'm going to get an engine out of a 77' 620 pickup. It would be way too much trouble to do all those steps.i just need a carb for the motor and they cost so much again thanx for info Quote Link to comment
PREACHPRO Posted June 9, 2009 Author Report Share Posted June 9, 2009 Oh and the 1.5l was an a series engine,totally different from what i really needed.i actually have an engine in my truck now.the original 1.8l but the head is messed up.someone ran it hot so i just thought i'll get another motor. I suppose i could rebuild it but i'm buying the engine out of the 1977 dat pickup for $200.00 and it just needs a carb. Quote Link to comment
yellowdatsun Posted June 9, 2009 Report Share Posted June 9, 2009 Also FWIW the J-13-15 will *NOT* fit using factory parts, unless you mean cutting off the motor mounts from the frame and then re-welding them back onto the new truck. Definitely not a bolt in. Quote Link to comment
