crank/pulley bolt
ImInked
  • Replies 7
All the same 27mm I believe. Place in gear and have someone hold the brakes on. Use a deep socket if you can and let the ratchet dangle down. Give it a sudden, hard kick towards the driver's side to loosen.
I have never had to use a puller to get any L or Z motor pulley off. Just tap the back of the pulley while pulling it forward. Never had to hammer it just keep tapping firmly, comes right off.
You mean passenger side
Lefty LOOSY
Righty Tighty
If the ratchet is hanging down a kick to the driver's side will do it. ... unless you mean in Australia????
