jodaddy Posted May 28, 2009 Report Share Posted May 28, 2009 81 720 z22. parts store gave me 180 degrees with a jiggler but book says 170 degrees. Which is it ? Thanks in advance. Joe Quote Link to comment
datzenmike Posted May 28, 2009 Report Share Posted May 28, 2009 Z22.... 170 for tropical 180 is standard (go with this one for best performance and drive ability) 190 is for the far north Quote Link to comment
jodaddy Posted May 28, 2009 Author Report Share Posted May 28, 2009 thanks Mike Quote Link to comment
Pacific coast Datsun Posted May 28, 2009 Report Share Posted May 28, 2009 Minor thread jack here. Is it ok to run w/ out a thermostat ? Quote Link to comment
Madness Posted May 28, 2009 Report Share Posted May 28, 2009 from what i've seen you'll just never reach proper operating temp on a cool or cold day. If you have an O2 sensor i could see how that could be a problem. Quote Link to comment
yello620 Posted May 28, 2009 Report Share Posted May 28, 2009 Minor thread jack here. Is it ok to run w/ out a thermostat ? NO Quote Link to comment
datzenmike Posted May 28, 2009 Report Share Posted May 28, 2009 Minor thread jack here. Is it ok to run w/ out a thermostat ? Street vehicles are carefully designed to work best at fairly high temperatures. This is where they run the smoothest, make the best power and torque, give the best mileage and the least wear and emissions. Run with a thermostat it will allow the quickest warmup and prevent over cooling. The radiator and fan will shed any excess heat and prevent over heating. The thermostat's job is to regulate the temp at about what it's rating is. You can run without a thermostat but there's no advantage to it. Your motor won't be running at it's best if you do. Quote Link to comment
