Newbie- rebuilt front end Need correct ride height
reystoke
Heellloo and (help),
Newbie here , 1975 620 truck
longtime mechanic.I have replaced all the bushings in the front end
and adjusted torsion bars as per 74 factory manual and front is too high.
I need stock ride height measurement ( distance from ground to top of wheel well or opening. Could not find in factory manual
Any help greatly appreciated
Thanks,
Reystoke
  • Replies 3
My 76 FSM list factory ride height. Measure the height difference between the two lower control arm pivot points, inner and outer. Actually four mount points when you consider both sides of the truck. Spec is 78-82mm difference. 3.073"-3.230". Seems tall to me, but i like them low. Good luck.
Does that make sense?
